Originally posted by mikemounlio
Ultimate Street suspension guide
This is a sticky topic.
That is a great deal. I need to look on amazon more often. I always forget about it. I normaly have such good luck on ebay tho. The top hats have been the only thing in the last 6 years that have been an issue for me.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Yeah I have found things on Amazon that were cheaper than rock auto believe it or not. And I have found things on Amazon that weren't even on rock auto haha.Originally posted by mikemounlio View PostThat is a great deal. I need to look on amazon more often. I always forget about it. I normaly have such good luck on ebay tho. The top hats have been the only thing in the last 6 years that have been an issue for me.
That is cool. I will try that when I do my Bilsteins next spring.Originally posted by Advancedynamix View PostGreat writeup. I love the use of using the rear spring perch as the spring top isolator.
+1 on the great writeup! :-)Last edited by TominMO; 12-28-2015, 07:04 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Yes! The top hat was used as a top hat. I used the front coilovers as they came (aside from springs and hole mods). Top hat fit nicely over the rod. The rod fit nicely into the strut mount.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Good write up Mike, how did the top of the new aluminum Hat mate with new upper Rio Mount (Bearing)?Originally posted by mikemounlio View PostYes! The top hat was used as a top hat. I used the front coilovers as they came (aside from springs and hole mods). Top hat fit nicely over the rod. The rod fit nicely into the strut mount.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Seems fine to me. Car turns so much better than before. So I guess it's working
Sent from my SM-N910V using Tapatalk1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
In the past I have used a washer between the front top hats and the Kia Rio strut bearing, just to distribute the load over a wider surface. This was just a precautionary measure taken from years of experience with coilover suspension on strut vehicles. All the spring weight is being supported by the inner shoulder of the strut mount bearing to spring hat thrust sufface. Aluminum is softer than the steel washer, so it is more apt to compress. If it compresses then there could be a slight amount of binding as the hat would then contact the outer bearing race. I tend to over engineer everything though. LolDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
^^ overkill is underrated!~Nate
Current cars:
FOTY 2008 winner!
Great right up, question how to achieve negative camber at the rear. I know advance had made a plate, was wondering if any one had tried that mod. Can alignment shims any good for this?
Sent from my 6043A using Tapatalk
JAMAICA TO THE WORLD
I don't complain, i just come plain.
gotta use washers under the spindle.Originally posted by alpaccino View PostGreat right up, question how to achieve negative camber at the rear. I know advance had made a plate, was wondering if any one had tried that mod. Can alignment shims any good for this?
Sent from my 6043A using Tapatalk1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Sent from my 6043A using TapatalkRecently bought alignment shims for the rear, code 75200....Originally posted by mikemounlio View Postgotta use washers under the spindle.
Free Shipping - SPC Performance Camber Shims with qualifying orders of $109. Shop Wheel Alignment Parts at Summit Racing.
We were fixing a problem of 1 inch of toe in, and changed the camber by zero. Very easy to use. I like them better than using a washer just because there is full contact.Contact me for information about Festiva Madness!
I bought 4 of these! I'm looking for -3 on the rear on race days
