Yeah. It can be measured in distance of rack travel or in rotation of steering wheel.
quick ratio steering rack
So, wouldn't a faster rack have either a longer throw with the same lock to lock, or same throw with lower lock to lock, or some combination of that? Cuz the Rio rack has a long throw traveled by fewer turns lock to lock, so it should be really fast, right?A mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82
Less turns lock to lock means less distance that you've got to turn the wheel to steer the car. This is a very good thing when driving the car on a race track or a really twisty road. My arms get really worn out with the stock manual festiva rack. The power rack is a nice upgrade.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
My "aspire" power steering rack is working beautifully, is 10mm longer each side so my tie rod adjustment was maxed out and barely had neutral toe. I chose to run the 10mm longer lower control arms and adjustment is within range and I scored some nice camber
What trans do you have and do you still have axle play without any binding? What axles are you running?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
That makes sense. You've got the axles to match the control arms. I think the axles try popping out if you try that with the stock WA axles.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
From what I've cross referenced in Australian parts catalogues, the 1.3 5 speed "aspire" over here uses the same driveshafts as the WA, and auto and F series and Capri non turbo all use the same driveshafts
10mm is a minuscule amount of movement to the inner CVs, and with the longer LCAs it's stretching them not compressing them so no chance of bindingLast edited by robotrob; 07-06-2016, 07:18 PM.
I consider it a bind situation if they hyper extend as well. But when they hyper extend they tend to pop out the tranny. That's what one of mine did when I ran aspire arms awhile back. I thought about trying aspire axles to remedy this, but I just put the fesiva ones back on. Over here the Festiva and Aspire 1.3 take different axles. The Aspire axles are a bit longer. This is because the Aspire control arms are longer. At least that's how I remember things to be. Lol. It's been awhile since I've had all the bits in front of me. I always wondered if it would work though, and it seems that's what you've done.Last edited by Advancedynamix; 07-06-2016, 07:27 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Hmmm. According to that they are the same. Interesting. Maybe there is some difference between the F series axles. I know my short axle kept popping out with my stock 4 speed and stock axles and stock spindles. It was an original axle too. Maybe they changed something on the aftermarket axles. Now I'm more confused than before, haha.Last edited by Advancedynamix; 07-07-2016, 06:54 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I was going to post again saying maybe the aftermarket manufactures allowed more tolerance in manufacturing so the same part can suit multiple vehicles..
What's even more interesting is that Capri non turbo uses F series 4 speed auto and F series 5 speed and the same driveshaft, but 1.5 4 speed auto WF uses same as Capri but the WF F series 5 speed uses different part numbers again
It confuses the hell out of me too and I think I've derailed this thread quite a bit... Though I have proven that running the 10mm longer WF control arms is a solution to the longer steering rack IF you use appropriate driveshafts and want the negative camber
I asked that a while back. Don't recall the answer, but I do recall that another member just trimmed the Rio inners and got plenty of room. Since you need Rio/Escort outers anyway, and a used rack will come with both, it makes sense to me to just do that instead.Any difference that makes no difference is no difference.
