I removed the u-joint from the column and then removed it from the rack on my workbench. Reinstalled to the new rack and the had someone on the inside feed it through the firewall while I installed the rack.
I did happen to have the column out (loosened, not removed) already to change the pedal assembly to add a clutch. The column is pretty simple to loosen, but not sure it is required to change the rack.
I never had to mess with the boot.
