13" slicks
  • 13" slicks
    Has anyone put 13 inch diameter, wide (7-10") slicks on their 'steve?
    I wanna know how wide I can get away with. 4x100 aspire hardware with sawzalled fenders and miata flares
    1991 Beastiva L BP autoX'er
    I think you could manage a good bit with your cut fenders. I have seen a few Festiva's with what I believe were 13" slicks, but I cannot recall which threads they were in.
    Will Samet
    How to find me:
    Feel free to PM me anytime!
    Instagram/Twitter: @WILLSAMET
      I run 13" slicks on the advanced suspension with 0 issues.
      19?? 150$ burnout car SOLD
      1991 (STRESS RELIEF)SOLD
        I had to get a wheel spacer but nothing else to make them fit. I will be trying out the hoosier a7 soon. Im on an older style of hoosier now but i think the size is still the same as the a7
          The spacer should be due to the wheel offset more so than the tire choice though
          I mean that a better offset would fix the problem. If the tire is too big and rubbing the spring perch, a spacer will fix that of course.
          Will Samet
          How to find me:
            Yup the offset issue is exactly the info I'm looking for - mike, what size are your 13s and what tire size is on em?
              If I find a 10" 13 that has the right offset to not require a spacer that'd be ideal! If not, then I'll bump it back to a narrower wheel
                A 10" 13 seems like it will be hard to find. Im not sure what mine are. I bought them used. I think they are sentra wheels.
                  There are some super awesome Vintage JDM wheels that pop up every now and then in 13x10, if you are ever willing to drop the cash
                  Will Samet
                  How to find me:
                    They make tons of dirt track style steelies in 13x10
                    Will Samet
                    How to find me:
                      The main question is what size tire do you want to run. The tire will tell you what rim width to run.
                        Idk if this is relevant lol. and 13x10 seems super wide to me!
                        this crx I see at autox has crazy wide wheels/tires and I saw they were 13"
                        I'm no good source of information but I think 13x10 wouldnt fit unless it had a lot of negative offset.
                        92 Festiva L - bp & hydro g, advanced coilovers, aspire brake swapped
                          13x7 +25ish is pretty much the widest you're going to fit under stock pulled/rolled fenders.
                          Better Than Nothing Racing
                          Way too many cars
                          :woc:
                            I've heard 22x8x13 size slicks talked about before. I'm thinking those fit without modding your fenders.
                            Jerry
                            Team Lightning
                            Owner of Team Lightning
                            93 L Lightning. BP
                              I will be trying out a 205 60 13 next. I want to feel the difference for myself between the different sizes. Before i make any changes to the suspension i will cut out the sway bar on my aspire beam. See if taking out some of that stiffness help me any.
