send it down to fl we have no emmision laws you can run downpipe only not worry about cat hitting rack ahah
My KLZE Festiva Build Thread
93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
In California you CAN swap the v6 if you take every single piece off the v6 donor car, and have it inspected and documented. We're talking evap, all vacuum lines, CORRECT ECU full harness etc. A proper clean install in other words, one we would respect anyway. The car also has to pass as the v6 car, which is newer than a festiva. If its a JDM engine you have to go locate the usdm parts like egr and the usdm intake manifold. Lots of hoops to jump thru but on club protege I'm following a hero up in northen cali who's either done 2 of them, or made one sold it and is helping another guy. Its been a while since i went poking on their site.1993 GL 5 speed
Isn't that the point :lol: seriously though, it shouldn't be too terrible but if traction is too much of an issue than i'll look into some stickier tiresOriginally posted by FFesti_90 View PostIn reference to what everyone told me when I mention FWD 5-cyl......your tires are gonna spin a lot (truth or not idk, but apparently that's what's gonna happen)
Thanks dad :lol:Originally posted by sasquatch View Postyou may resume posting
No need for the BP bell housing since i swapped the diffs to make the probe tranny work, plus i don't think i could spare the room of the thickness of an adapter plate but thanks anywayOriginally posted by Gforcefd View PostSo are those pictures with the transmission in place as well... Very sweet indeed! You know how many KLZE festiva's are going to start showing up here soon?
Chris, if you decide to go with the stock BP bellhousing for some reason I have just sourced a place to get a diagram of the adapter plate needed to bolt a KLZE to miata bellhouse which is the same as the G trans. Let me know and I will pass you the info.
Very awsome indeed. You will have one nasty autoX'er if you put a LSD in there too.
Oh and for FM4 we will have to car pool down together when the time comes, I am planning far in advance for it as well. The only thing possible problem is the wife and I are starting college again and that may make our weekend shorter than planned.
I like the idea of keeping the stock fuel tank plus it shouldn't be too bad for fill ups and the V6 badges are definately something i will get once its complete, thanks for the linkOriginally posted by DriverOne View PostThat's crazy close! Have you considered a fuel cell? I imagine that the V6 with that tank would be like a true V8 in a Bronco: Race to the next fuel stop! Are you going for sleeper? Just wondering 'cause a set of these would look pretty cool on the grille and beside the Festiva emblem on the back! http://cgi.ebay.com/ebaymotors/1980S...item53ddf0c029
Your right on that one :evil4: i have a heavy right footOriginally posted by nonamekid View PostThe mx-3 with the v6 got over 30 mpg, so a festiva with the KLZE should get around 30-35 mpg as long as it is driven conservatively. Knowing this won't happen, i would expect a fuel economy of 25-30 mpg.
And the joys of living in Ontario, when it comes to emissions, if a car has any engine that was never available from factory it gets put in a "hot rod" class and that limits are raised, so B6, B6T, BP, KL-ZE, they just put it in a hot rod class and run the testOriginally posted by FB71 View PostIn MD, a boosted BP would squeak past emissions testing, because it's a 4 cyl, like the original engine. Having a v6 in a car originally equipped with a 4cyl is instant failure.
However, awesome work!!! Can't wait to see it finished!
Your mock up motor has the obd2 exhaust manifolds. Sourcing a set of obd1 manifolds would save you a lot of room. They don't have that big flex pipe in them. And you might look into the v6 mx3 intake manifold. The neck curves towards the front of the car and makes intakes in tight spots much easier. The mx3 flywheel is also 5lbs lighter.
:lol: thanks collegeboi!
I actually have the same thread going on clubprotege and i've been getting the same kind of advice, but its always good to hearOriginally posted by nixapgt View PostYour mock up motor has the obd2 exhaust manifolds. Sourcing a set of obd1 manifolds would save you a lot of room. They don't have that big flex pipe in them. And you might look into the v6 mx3 intake manifold. The neck curves towards the front of the car and makes intakes in tight spots much easier. The mx3 flywheel is also 5lbs lighter.
No problem! Pics pics pics! Maybe FOTM?Originally posted by Damkid View Postthanks for the linkIn love with a MadScientist!:thumbright:
Well i did a little bit today, i cut the rad support off so i can make some clearance to get everything sitting straight, i need to get some steel from work now to re-attach the rad support and to start making the front tranny mount
This is where it needed clearance
I didn't cut too much out yet until the front trans mount is made and i can determine how much needs to be cut out
sweet.... couldnt you just make the front mount a bit taller and push the motor back a bit? or make the rear one smaller?
Mike, AKA the sasquatch
The rear mount has the tranny about 1/4 inch away from the steering rack and there's not much room to tilt the engine back, but once i straightened out the engine it made a bit more room at the back
I was thinking the same thing :lol: i'll probably get a set of headers to help with the clearance and to help keep the heat away from the rackLast edited by Damkid; 12-06-2009, 11:21 AM.
Thats actually what i was thinking too, since theres no room in the engine bay for a turbo :lol: and with the history of the car it'd be nice to keep it turbo'dOriginally posted by 25Horseplay View PostGet it all running and look into a rear turbo like Eurotiva has!! That would be awesome!!!!
