My KLZE Festiva Build Thread
  • Chris,
    It looks like you have enough room to stick on a 135 degree silicon coupling or maybe a 90 degree one and clear it without issues?
    • Originally posted by Nerd Racing View Post
      (wrong port shape)
      exactly, round runners into square ports is a bad idea.
      The Festiva Store
      • I'll be looking for the millenia manifold so i have the curve neck with the proper runners so i don't lose any power and can still clear the brake master
        I tried tig welding the mazda valve cover and just made a mess of it, so i'll be using the ford cover
        • This might work for you on the intake...
          Your source for silicone and rubber intake hoses and parts. Warehouse pricing.
          • ^^Thank you very much for that link, those really do look like they will work perfect plus they're cheap!
            • Originally posted by ketchup View Post
              could you relocate the brake master reservoir by pulling it off and tapping the master with a pipe tap? Then add 90 degree nipples and just clamp on some hose and mount the reservoir right behind the drivers strut. just pull the master apart to tap it. there is a snap ring pull it out and keep everything in order its spring loaded by the way. if you get brake safe hose it would work perfectly. maybe you could use braided stainless lines too
              this is a great idea if you want to keep a smooth-flowing intake tract by avoiding a crazy 90* coupler.
              Originally posted by muscle_Car1 View Post
              how would this be actuated? with the air inside the pipe?
              Just mount the reservoir higher than the master cyl.
              Thats a good site Nickb, its hard to find odd couplers.
              • Originally posted by Damkid View Post
                no problem, your doing a great job keep up the good work.
                you could donate your old motor to me if it makes you sleep better
                • wow, looks great!
                  -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
                  -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
                  • Hey Chris I saw this in an other thread
                    BP swaps are the best N/A swaps to do in a festiva, and is fairly easy and well worth doing
                    And now you have this. What do you think now ?
                    • inline 4's are so 2000's. New decade, new engine family.
                      1993 GL 5 speed
                      • so that is what my new motor looks like sweet!!
                        • Originally posted by Maxtiva View Post
                          The BP swap is still the easiest with the most power N/A swap, the V6 Swap is a LOT more involved :lol: but it will be much better than a BP
                          Yup thats the one your getting
                          • Originally posted by getnpsi View Post
                            no no no... you start counting at 1 not zero, its the last year of the decade... I hate that everyone screws that up...
                            Facebook Me!
                              Should have told that to my old VCR 10 years ago.
                                actually, you have that backwards... you normally don't count 0, but since in this case 0 is a year (eg 2000), it must be counted. 2000-2009 is 10 years, even though it doesn't appear that way. remember, there was a year 0 and not just two 1s (BC and AD)
                                1. 2000
                                2. 2001
                                3. 2002
                                4. 2003
                                5. 2004
                                6. 2005
                                7. 2006
                                8. 2007
                                9. 2008
                                10. 2009
                                /hijack
                                -Caleb
                                Originally posted by cracked.com on the M203 w/ M433 HEDP
                                So, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
