So today I clocked the center section of the turbo so the drain faced straight down instead of the 45 degree angle it was on (newb mistake on my part) and I let the PCV vent to the atmoshpere and went for a drive... No more clouds of smoke after running under boost!!! WOOT WOOT!!!
So I went for a celebration drive, it still sputters under boost at 4k+ rpm, I don't have a wideband hooked up yet but I'm assuming it's running lean, I have bigger injectors that just need to be installed
But while i was out i noticed a trail of oil that followed my car when i parked it, my rear main seal has gotten much much worse, this was after 20 seconds of idling
So I decided i cant hold off on changing the rear main seal any longer, so i cleaned the garage tonight and now have my parts ready to be installed tomorrow
We have millenia S injectors (50cc larger then stock KL ones) installed in polished fuel rails, should hopefully solve the sputtering issue under boost
Timing belt pulleys, the current ones are squeaky and annoying as hell from sitting for the passed year
And the much much needed rear main seal
