Damn that looks good! Is it going to be strong enough though?
My KLZE Festiva Build Thread
- Unknown
- Quentin Crisp
- Bumper Sticker
1/4" thick steel, i'm sure it'll be strong enough :lol: besides there's not really any torque on the bracket anyway, its more or less there to support the intermediate shaftOriginally posted by MONSOON View PostDamn that looks good! Is it going to be strong enough though?
Ahh good to know. Was just lookin out for you.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
i figured it was better then grinding down the block to get the int. shaft bracket to sit flush with the block and not enough mounting holes behind where the bracket sits compared to the engine :lol:Originally posted by muscle_Car1 View PostInteresting idea for half-shaft mounting....
no progress yet,Originally posted by Nickb1907 View Postany progress, i want to see the festy driving soon
the first time i put the ZE in i messed up the threads for the crossmember bolts so i didn't get the bolts tight, i've since fixed the threads so that problem is fixed. The other day i put the ZE back in, got the bolts tightened up and seen how little clearance there really is to the frame rail, which is less than i originally thought
so i've decided to knotch the frame rail that way if i ever need to change the belt i won't need to pull the engine, so i'm waiting on some steel from work to come in but in the meantime i've started on the engine mount
Yeah probably good you are notching the frame rail if you have to use that outer belt instead of removing it. My alternator was sitting that close on one of my BP installs, any time I went around a sharp corner fast it would hit and make a fun noise.
Same thing for meOriginally posted by Gforcefd View PostMy alternator was sitting that close on one of my BP installs, any time I went around a sharp corner fast it would hit and make a fun noise.
Poverty produces creativity
