Looking good man. Alot of hard work going into this.
My KLZE Festiva Build Thread
Well, I wouldn't say "hard" work, just tedious work to get it all functioning like it came this way from factory
Haven't touched it lately, I'm probably gunna wait til the weekend to do anymore to it
I won't be converting it to AWD though, too many added headaches that I just don't wanna deal with lol but I'll probably never be done with this project, I'll always continue upgrading it until the day I sell it lolLast edited by Damkid; 03-06-2014, 04:54 AM.
Changed my mind and did some work tonight on it lol
First I added some gussets to the push rod since I wasn't sure how durable it was gunna be without them
Brake booster/master bolted back on.... I hate working on the nuts that hold the brake booster on, I'd rather take a punch in the face then un-bolt the brake booster lol
Then I got the slave bolted up and started running the hard line.... Not much clearance with the fan and line but it's enough to never cause issues
Nicely with the frame rail.... It's just hanging there until I can pick up some pieces to bolt to the car and hold the line steady
I've been pretty broke lately so I haven't picked up the flex line yet to finish this off, but once I get the flex line I'll just to hook it up and bleed it out and my hydro clutch conversion will be complete
I always read this thread, and it makes me want a bigger motor....-Greg
Redneck Engineer
FOTY - '09
^^do it :evil4:
Picked up a flex line to finish the lines and here's the final routing for the clutch line
Then I tried bleeding the system only to find out the MC is toast... Ugh
Sooo onto something different while I wait on a new MC.... I've still had the 323 GT rear seats awaiting install so I got a start on it tonight
There will also be a lower piece of angle iron to attach the hinges too and the lower section of the seats... So far I'm really happy with the fitment but I still need to check how the seats line up with the panels but here's the fitment so far
And yes the seats need a good steam cleaning
Some may ask why I decided to run two pieces of angle across the width of the car... I have future plans that will tie into these.... I intend on running a water-to-air IC and a custom made "box" reservoir will be built to fit between the angle iron allowing me to keep some of my storage space... But that's a long time away yetLast edited by Damkid; 03-23-2014, 02:08 AM.
Did you say rear turbo?...-Greg
Redneck Engineer
FOTY - '09
:lol: that's your specialty man, I prefer hearing the turbo from the front of the carOriginally posted by eurotiva View PostDid you say rear turbo?...
LolOriginally posted by Chultz View Postcouldnt you just put the engine at the back and just a turbo in the engine bay since you like hearing the turbo up front??
seems logical to me haha
Sent from the depths of hell.Ford Festiva 1991 WA Model (5 Door)
Nicknamed the car 'The Chiva' (Chilli Festiva)
Avg Economy:
Highway - 7.32L/100km
City - yet to be determined.
Backrests fully mounted
Still need to make attachment points for the bottom cushion and trim the panels to fit since the backrests are slightly wider then festiva seats.... I'll also need to trim the rear speaker panels to clear the angle ironLast edited by Damkid; 03-24-2014, 02:14 PM.
i just looked at this post one question? are you swaping the probe diff for the 323 diff? instead of doing that why don't you change the side gears into the probe diff and have the same diff in the probe but different side gears if the housings are the same they should fit in there. like i said i just happen to run across this and read it, i don't know if i read it wrong.Originally posted by Damkid View PostI've had a spare G series tranny for a while and the other day i picked up this probe GT tranny, i've always been intrigued by the BG V6 swap in the 90-94 323's
So the idea occured to me if there basically the same tranny (internally) except for different bell housings, then i "should" be able to swap the differentials making the probe tanny able to accept the 323/capri axles, which "should" make a V6 swap relatively simple
so i tore down the two trannies today to compare and here's what i found
The 323 tranny with the 5th gear cover off
now with the case separated
And a bare empty tranny
The probe tranny with the case separated
bare empty probe tranny with all the parts spread over the bench
And here's the part i was looking to find out, the differentials side-by-side, the 323 is on the left
You can see the probe's ring gear is thicker but it's not taller that the 323's but as far as i can tell thats the only difference in the differentials other than the spline count
The only difference i've spotted so far with the gear sets so far is the gear that drives the differential is thicker on the probe tranny
The 323 gear:
Probe gear:
I set the 323 differential in the probe housing and it fits like it belongs, so when i re-assemble the tranny i'll use the 323 diff in the probe tranny so it'll be ready to swap into a festiva :evil4:
