My KLZE Festiva Build Thread
So i did a little bit on the car again tonight, i notice the front valve cover has a crack in it so i took it off and i'll try to tig weld it tomorrow at work, if not i'll just use the Ford valve cover, but i'd rather have it say Mazda
i want to make some more clearance with the pullies and frame so i figure if i can mount the alternator to back side of the engine i can run the alternator on the inner grooves of the crank pulley and shave off the outer grooves of the crank pulley and instant clearance so here's a pic of where i want to move the alternator to, it looks like it'll be a tight fit but i think it'll work
And this is to show that i'll have plenty of room between the axle and exhaust, and yes i still need to make a bracket to bolt the intermediate shaft to the block
Originally posted by Damkid View Postif not i'll just use the Ford valve cover, but i'd rather have it say Mazda
Originally posted by 25Horseplay View PostNNNOOOOOO.............................its a Ford!!!!!!!!!!!!!!!!!!!!!!!
when i was looking for a car i said i would NEVER EVER buy a hyundai or a kia... i hate them so much... i have only found one kia part on my car and every time i see it i get a bit mad... but the rest is all good im working on taking EVERY bolt off the car and put it back on... then that way it wasnt assembled by kia...
Mike, AKA the sasquatch
Originally posted by sasquatch View Postim working on taking EVERY bolt off the car and put it back on... then that way it wasn't assembled by kia...
Originally posted by sasquatch View Postwhen i was looking for a car i said i would NEVER EVER buy a hyundai or a kia... i hate them so much...
Originally posted by 25Horseplay View PostI would have never bought one of these if it wasn't a "FORD" Festiva. Which by the way they aren't really Mazda's either, they were built by KIA
Yeah only the Japanese ones are mazda built
Originally posted by resuwrecked View PostNO! Mazda!!! c'mon guys!! ford just sold 'em to bring down the fleet mpg's thanks to crappy cars and trucks that WERE built by ford.It's a good thing you don't read the stickies, you might of learned something.Poverty produces creativity
could you relocate the brake master reservoir by pulling it off and tapping the master with a pipe tap? Then add 90 degree nipples and just clamp on some hose and mount the reservoir right behind the drivers strut. just pull the master apart to tap it. there is a snap ring pull it out and keep everything in order its spring loaded by the way. if you get brake safe hose it would work perfectly. maybe you could use braided stainless lines tooYOU WILL HEINZ 57!!!!
Originally posted by 25Horseplay View PostI would have never bought one of these if it wasn't a "FORD" Festiva. Which by the way they aren't really Mazda's either, they were built by KIAThe left lane? Are you crazy!!! I never drive in the left lane...It's full of freaks driving the wrong way and charging right at you!!!
Mine is Sooooooooooo confused. Ford name, Mazda motor and trans, built by Kia on the door jam. I call mine a KMF. Kia -Mazda-Ford. Will see if my Brother can make a name tag saying that at his machine shop. Yep they have CNC.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Originally posted by ketchup View Postcould you relocate the brake master reservoir by pulling it off and tapping the master with a pipe tap? Then add 90 degree nipples and just clamp on some hose and mount the reservoir right behind the drivers strut. just pull the master apart to tap it. there is a snap ring pull it out and keep everything in order its spring loaded by the way. if you get brake safe hose it would work perfectly. maybe you could use braided stainless lines too
Also why go through that if all he needs is the mx3 intake mani
Last edited by muscle_Car1; 12-29-2009, 01:19 AM.It's a good thing you don't read the stickies, you might of learned something.Poverty produces creativity
because the MX-3 intake flows like shiz compared to a true curved neck KLZE or Millenia manifold.
(wrong port shape)89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
