My KLZE Festiva Build Thread
  • Hmm I did not know that, thanks
    • Originally posted by bhazard View Post
      Rofl .... Chris you're a blind redneck...eh
      ohgod i died inside when i read this.. LOL!
      • Yeah....what happened to my post anyway?
        91GL BP/F3A with boost
          Which post? As far as I know, none of your posts got deleted
          • The one he quoted
            • Brad, your a blind redneck, if it got deleted, how could he have quoted it
              • Originally posted by PhoenixSHO View Post
                BTW rockauto sells bulk lines by the foot. The size you want.
                Coolant , fuel , oil , name it.
                Ya but do they sell Heater Hose? Just had to
                • Play nice boys
                  1991 blue L, 5 speed.
                  1988 red L-plus-all stock.
                  • That's no fun lol
                    Since I'm posting in this thread anyway, I might as well say that I'm gunna be picking up some oil tonight and I'll be starting to get the motor back in to fire it up
                    • at least he didn't call you nice boys! It could take a guy
                      years to get his reputation back!
                      • Spent a couple hours on the festiva tonight and got the motor back in the engine bay
                        Here's a little bracket i made up to support my oil return line
                        And as you can see, the return line has a nice downhill slope all the way from the turbo to oil pan
                        I only have a few more things to tidy up on it and i will be able to fire it up and move it around under its own power again
                        And for anyone who says my return line will swell up and cause issues, i have a chunk of it sitting in a bucket of oil right now, it's been soaking for 3+ days already and no sign of swelling, i'll be keeping an eye on it to see if i will actually end up having issues or not
                        • Originally posted by Damkid View Post
                          Chris, the section of hose that drops down beside your exhaust manifold worries me. Is it possible to drop it down farther, sooner? I'd hate for you to cook your return line and then evacuate your oil supply. I know this is like a weekend DIY'er second guessing a pro, but I was wondering why you chose to run it like you did. Maybe a hard line there instead? Just askin'!
                          • That is honestly where I have to run the line, once my rad is in place, the return line must go where it is,
                            a hard line is definitely not a bad idea though but there is about 1" clearance between the line and manifold, and remember I will be adding lots of header wrap which will help out lol
                            • He could aways wrap the hose with aluminum foil. I did it on the ecu harness of my element, it was very close to the turbine housing and couldn't be moved any further away.
                                Good deal. If you use hard line in between the two custom supports you made, you should lose 3/4 of your pipe wall diameter, and open up more space.
