ok so time for a lil update. I finally got the crank pulley that I needed from Damkid (Thanks again btw). I went to mount the B8 and it seems like everytime I try and put the back tranny mount in the pass. side mount will wanna pop outta the bracket. Like towards the front of the car. Then I'll try and start with the side mount and the rear mount wont line up. So bein that said can someone point out as to what I'm doin wrong??............................I hate F-series hydro trannys!!!!!!!!!
my first swap......ever!!
Bolt the front engine (pass. side) mount first. Then see where the other mounts line up. Move them accordingly. I know the only f-series I've seen used a stock eseris rear mount. But it was crashed in the front so I can't say it was correct.-Greg
Redneck Engineer
FOTY - '09
Post a [FS] and you may get more responses, if your serious!'93 Blue 5spd 230K(down for clutch and overall maintanence)
