Mike I just got the same setup for mine. Let me know how it goes. Mine didn't come with the fancy display, but same model and all.
sasquatch's bp swap thread
-Greg
Redneck Engineer
FOTY - '09
sweet, i thought this would be a better thing to buy cause its like 4 gauges in one and if i plug in a laptop its like 20 in oneOriginally posted by eurotiva View PostMike I just got the same setup for mine. Let me know how it goes. Mine didn't come with the fancy display, but same model and all.
lol...
i got it off of craigslist... 250 for everything and the EGT sensor hasnt even been usedOriginally posted by timmay89 View PostThat looks awesome! Did you pay retail for it, or where did you get it?
the guy lived up the side of a mountian and the road leading up to his place was twisty as heck
it was SO much fun to drive on, i was rippin around in my moms corolla
i marked the road on my gps so i can find my way back for some fun one day
Mike, AKA the sasquatch
lots of work done on the car today but it looks like i did nothing lol... all the work i did was wiring, all under the dash... my back is not felling to good, 6'5" and trying to bend in to the foot well on your back and look up in to the dash to se where your wires are is not fun lol... but i got EVERYTHING re-wired and its MUCH better
now i can leave my key in ACC and not have all my gauges running... they are wired in to the ON position and the power dosnt cut out in the START position, so the zietronix dosnt go back to the "start up" procedure
here are some pics...
first off i got rid of all the gauges on the "A" pillar... i was gonna have "fuel pressure", "EGT" and a wideband on the pillar but the zeitronix dose all that so thats fine with me
i just got to get the fuel pressure sensor and then im set...
a closeup of the tach, zeirtonix, oil temp, oil pressure and water temp gauges...
next is the radar detector, now hard wired in to the key so now i dont have to shut it off each time i left the car
and if i dont want it beaping at me all the time i just turn off this switch and it will turn off, no more fighting with that stupid rotary dial
closeup of the zeitronix
i LOVE this thing
looks so nice and its easy as heck to see, i was kind of worried about not being able to read it but its easy
all of the stuff lit up
i dont know why the 3 gauges in the center vents are blue... they are white... stupid camera lol...
and last but not least... i took apart the tach and painted the back cover and shift light flat black... from the outside its much less noticeable
stelthy
more to come
ya, if only i had the money to do all the things that i want to it
one day
been a while since i checked this thread :lol: nice start on the wire tuck, it sure makes things look so much cleaner
ya i dont like the look of wires everywhere
so every wire i run im hiding it as best as i can
That is an awesome idea, if I ever switch the festiva into a standard I will wire tuck.
ok an update...
i should have my manifold middle of this week sometime
some work done to the car the last couple days.... made the intercooler all shinny
one side done...
before
after
all done
next is a racing seat that i have had for a long time... i put in the basement and the cat slept on it for the last 6 months lol... (along with my mint condition mr2 seats
) so i finaly got around to making a bracket to put it in the car cause im tired of flying around the car when trying to take some corners fast... i plan on doing some autoXing this year so this should help me out some
camera died after taking that^ pic so i didnt get a pic of the fram cause it was charging... its nothing special tho...
painted up some rad clamps.... lol...
and next to finish is the seat selt bar to hold the 5 point harness
the stock seat belts are gonna be left in the car so i can quickly buckle up and not spend like 20 min trying to get the 5 belts to all work together lol... and trying to sholder check with a 5 piont harness is allmost impossible...
i know the seat looks like its tilting but its just the pic...
and a shot from the outside... the seat is very low in the car and its far back but im tall... it fits me good
if i could i would like to move it back more but i cant
oo and the seat cover is getting washed lol....
more to come...
i made this bar about 2 years ago and never used it.... untill now
its amazing how much my metal work skills have improved in the last 2 yeard lol.... it looks skechy but its STRONG, i was just in the back of the car hanging, jumping, kicking and beating the $#!+ out of it, and it didnt move
so im happy with it.... i just hope tech likes it lol... if not its only 4 bolts and its out
and the bast part about it is that i still have all the stock seat belts in the car
seat cover is off for washing too
if your wondering how the thing is held together its like this.... the bar that goes from the front bolt to the rear is one solid pipe that has flattend in the middle and then bent around the cross bar, then a bolt holding the two bars together....
more to come...
ok i got my manifold and it fit on the motor but its WAY to close to the firewall.... i have tried everything that i can to make it work but its not gonna work with these mounts
im gonna try to bring it over to my friends house and make a new cross member so the motor will sit right... more upright and farther down.... ooo and i had to "adjust" my brake lines a bit... bent it a bit to far for old lines and one cracked so i got another thing to replace... it just never stops
