but yours was before turbo... if i tried to have 1 7/8ths after the turbo (turbo back) it would choke it up like crazy... the less back pressure you have AFTER the turbo the better... it will spool faster and get boost lower down in the rpm range... from what i have been reading going from 2.5inch to 3inch piping they gained torque cause the boost came on 500 rpm faster on avrage... and was a nicer sound IMO... the only thing that i have never heard was having the muffler so far up the exhaust... i dont plan on having anything after the first muffler, so im wondering what it will sound like with all that pipe open from the muffler to the tip... its gonna be about 8 feet im guessing...
sasquatch's bp swap thread
Mike, AKA the sasquatch
Your not remembering that Sasquatch does EVERYTHING in excess. remember how many lights he had on his car at one point? I think we should be happy he's not asking to put on 4" piping, lol.Originally posted by eurotiva View Post3 inch is way too big. I've seen cars push 700+ hp thru a 3 inch. Mine made 154 whp thru the stock 1 7/8ths.
my friend has some 5inch left over from his diesel truck... hrmmmmm
3" is too big, 1.5 for the wastegate sounds ok, since I think you got the same one I did, which is 38mm, close enough to 1.5". A wastegate routing like in your drawing wont scream, it will sound like a car with a 1.5" dp dumping into a 3" catback, ontop of the exhust frow from the turbine. Open dump will scream. If you want it to be loud when it hits the gate then run the dump tube down under the engine and dump it there. I got the v-bands off ebay. nice stainless with a ring on one flange surface and groove in the other, so they line up perfect.
Dump under the car or run to the dp like conventional setups, and loose the cat, or gut one or something.
try it, report back with vid of what it sounds like. it will probably sound like a muffled fart, like a civic with a rusted out muffler. What are you doing on a civic forum anyway? lolOriginally posted by sasquatch View Posti dont plan on having anything after the first muffler, so im wondering what it will sound like with all that pipe open from the muffler to the tip... its gonna be about 8 feet im guessing...
thats where i got my turbo and intercooler
tons of ricers cant drive and crash there turbo civic... lol jk...
Makes me want to put the BP into my car!! I would have to scronge a manual tranny from somewhere.
I like the coil over spark plug set up you got there.
Looks like funAspires and Sways all around, Miata B6 installed, KYB G2Rs just installed in front. Wish for coil overs someday.
ok a update
i started doing a wire tuck
i saw damkid doing it on his kl swap and it gave me an idea
before... sorry about the bad pic...
after
i tucked all the plugs and the relay behind the fender to hide it all
looks alot better IMO...
also added some nice fuses to get rid of those ugly looking wires
tied up some wires for my gauges, sound system and harness...
and i thought i would show where i stuck the water temp sensor... from what i was reading in the b6t book i have this pipe flows the water around that has just come out of the block and head so it should be the hottest and best spot for it...
also moved my coil back to the first spot i had it casue the plug wire i have now is long enough lol...
over all shot of the engine bay...
shot of the intercooler and piping... im gonna leave it out for a bit untill i get the turbo in it...
ooo and last but not least.... back when my car was running i had a VERY hard time seeing what my speed was when i was on the road at night... with the extra gauges i have in my car shining in my eyes, my brighter headlight bulbs and the cars headlights shining in my eyes like crazy i couldnt get my eyes to focus on the cluster and see the speed i was going
... well turns out 2 of the 4 bulbs where burnt out lol... i got some new ones but it still wasnt the brightness i wanted
here is a before shot... with ALL 4 bulbs working...
and without changing ANY setting on the camera or anything here is the after shot
i took out the thing that turns the light from white to green and i LOVE it
so much better
ill let you guys know how its to drive with at night... even if i have to dim the dimmer switch down to like nothing thats fine... it will just make the bulbs last longer
lol...
more to come
Ya it all looks great! I am very envious of your interior lights! I might just steal them to get mine working!!! lol
got some new parts today
zietronix wideband
now im off to put it in my car
here is some info on it... http://www.zeitronix.com/Products/zt2/zt2.htm
ya it has LOTS of cool stuff on it
ill do a vid of all the cool stuff on it when i get the car running...
im trying to put it in my car and i finaly found a spot to put it (beside my tach) and im in the middle of re-wiring ALL my gauges... alot of wires running everywhere for my alarm system and 90% of them i have no clue where they go
lol...
im hoping my manifold will get here in the next few days... i want to drive it
