My vacation project
Originally posted by freshtiva View PostOkay Im at the " Sorry I ever started this project " stage.
Axle boots bad, LCA bad, struts bad, tie rod end bad, steering rack boots bad, sway bar bushings bad, etc. Going to have to make a list and check my parts inventory .
Ka Ching !!!
'89 Ford Festiva LX :fred:
'12 Ford Focus
Day two, bad motor out, Jerry pushed back, Booger moved up. Ordered some parts. Break time for a ice cold Bud light with lime( wrench lube 8^) )
looks like its going good so far (aside from the junk lca's and such) I just pulled the motor out of my new festy "mint" and i gotta ask you..... is it easier taking the engine out with a hoist or by brute strength? lol
i really gotta buy a hoist
Originally posted by ckiesman View Posti gotta ask you..... is it easier taking the engine out with a hoist or by brute strength? lol
Originally posted by 91blufestiva View PostSweet project Marcus, if only I could use booger as a B6T donor car, I love the colors.
Day Three : ( mowed all day yesterday )
Good motor removed from booger and swinging free. Man this solo wrench work is hard on an old blind man with broke up knuckles. Id pay someone wage just to hand me things. The getting up and down is wearing on me. Back out to put tires on booger and roll it out of the garage. Hopefully will gain enough room to get the other cars back inside. They been airing out for the past three days.
Originally posted by ericsmith32 View PostMarcus if you need any help your not to far. Don't think I'm doing tomorrow (pending approval of the wife) work this weekend though. I wouldn't mind helping one bit just let me know.Last edited by freshtiva; 09-01-2010, 04:53 PM.sigpic
Originally posted by ericsmith32 View PostWell it's a open offer.. ever need a "extra" hand let me know! I'm running out of stuff to tinker with around here. BTW did you hear PNP is 1/2 price this weekend? Wish I knew when these come around a month before I need a 1.8L.
Thanks buddy, that goes both ways if you ever need an extra hand or two. Free advise too :p. PNP half price ?? mmmm, I am on vacation you know.sigpic
Did a complete brake line removal from Booger today. Besides a little grease on them they are in excellent shape. Probably the best Ive seen on a 21 year old car.
Finally got back to this for awhile today. Encountered so many hangups before it was hard to force myself back to it knowing what laid ahead. The right side LCA bolt had snapped off, got it out today. Have a rust problem in lower front support compounded by stubborn cross member bolt which just twisted out when I put the impact on it. Also where the brake lines run through the cross member a bunch of moisture holding dirt has nearly rusted out the brake lines. Ive got good brake lines ( see above ) that Ill try to install tomorrow. Also have a good plan to repair the rust issue in the lower front support beam. Just a small update. Pics below.
Worked on the brake line swap today. Check out the difference between the old and new lines. If you havent crawled under you car and checked out your brake lines lately you may want to. The tend to rust out where they are held on by the clamps.
New steering racks boots.
Lots of cleaning left to do. Might work on the motor some next. New water pump, valve cover gasket, timing belt, plugs, wires, disty cap, rotor, cleaning and painting, etc.
