My First Festiva
  • Less filling; tastes great!
    Karl
    • Took a week off for the holidays. Have been mocking up the mounts and doing some house keeping to get ready for installation. Drilled out shifter holes in Festy to make room for Protege shifter. Its a little nicer and will work better with the swap. Cleaned up the distributor and put on the new cap. Did some parts cleaning and prep work for the cold air intake we are going to fab. Finished installing the rear interior panels and rounting the battery under the carpet in the hatch.
      We are hoping (fingers crossed) to get a full day in on Saturday.
      What still needs to be done:
      Custom mounts and front support
      Shifter
      Cable clutch conversion
      Cold air intake
      Brake lines
      Rear mounted battery box and connectors
      Rear seat installation
      Front axles
      Alternator and belt
      Valve cover
      Fuel lines and vacuum hoses
      Coolant hoses
      ECU and wiring harness
      Speedo cable
      Throttle cable
      Plugs & wires
      Filters & fluids
      Wipers and washer lines
      Extras to get done:
      Sound system install
      - 4 x 6.5 speakers
      - 700watt 4 channel amp
      - 2 x 10 subs
      - 1000watt mono block amp
      - Kewood headunit
      - Crossover
      - Cap
      Power lock conversion
      Tint
      Alarm
      Hood pins
      Rear top mount antenna (shorty)
      Rat Rod side mirrors
      GPS Navigation
      Tachometer
      93 Festiva L (B8 swap in progress)
      • Got passenger side mount adapter built. Also, filled the rubber bushing with window sealant. This is supposed to add stability and make the mount more rigid. Will take some pics tonight.
        • PS Frame Support
          We got the frame re-supported on the PS and the DS support cut out. Just need to weld, grind and paint it.
          • Updates: Mounts, Interior, Engine
            Engine got some paint upgrades...
            Engine mounts filled and painted...
            Passenger side mount completed...
            Backseat painted reassembled and installed...
            Dash cleaned and floor mats fitted...
            Going in soon...
            • It's looking beast! Is the hardboard just particle board?
              91 Festiva BP Autocross/Track/Rallycross hopeful
              14 C7 Z51
              • Originally posted by Grey Vw View Post
                No not particle board...its just like peg board but without the holes...the exact product they use to make door panels just a little thicker. They sell it at Home Depot and Lowes.
                • DS & PS Mounts Done
                  PS Mount Installed:
                  DS Mounting Bracket:
                  DS Mount Adapter Fabricated:
                  • Looking good.
                    Your gonna enjoy that motor. Still easy to work on (more room than a bp) and lot's of torque.
                    -Greg
                    Redneck Engineer
                    FOTY - '09
                    • Originally posted by eurotiva View Post
                      Looking good.
                      I know right...just enough room for a turbo and some cold A/C. :p
                      • I really like the idea of getting rid of the crossmember. First time I've seen more detailed pics of the mounting system. Thanks!
                        Karl
                        • Started making the clutch cable adapter last night. We are converting from hydro to cable clutch. Pics coming soon. Also modified the throttle cable bracket on the swap motor to work with the feisty cable. Works great and leaves room for adjustment.
                          • I heard you started your car today and have a short video. Is that true? ;-)
                            Neil
                            Jesus loves me. This I know.
                            93 L track prep in progress
                            88? Parts car-sold
                            86 b2000- pisses of HOA-sold
                            • Originally posted by gorgonheimer View Post
                              Yes Neil...I will get it loaded.
                              • 93 Festiva B8 Swap - First Start
                                FIRST START!!!
                                Ran a preliminary start last night. This thing sounds sick without a muffler. Here it is guys, enjoy...
