Now you have a project Brad lol
Thoughts on building a drag car...
is it official or what?1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
Re: Thoughts on building a drag car...
I hate winter.
Trying to decide on which flavor of Stratified's PNP ECU I should go for...the one for the EGT or the plain universal one or? I'll be running a festiva harness...91GL BP/F3A with boost
BP ECU's and the B3 ECU uses the same connector, I thought you knew that lol
I do know that. However his universal ECU is $450 and the EGT specific one is $575...the universal one has the same connection just doesn't come preloaded with all the same stuff.
Have you seen Stratified's product lineup?91GL BP/F3A with boost
I haven't looked at stratified's site in a long time
Ya those DIY kits confuse the hell out of me, it's well worth buying a pre-built unit lol
Yes and Lex provides support himself until your car is running. No need to worry if I soldered a resistor the size of a flea wrong.91GL BP/F3A with boost
Yeah if you go with the plug and play unit you won't need lex. Mine was running instantly. Follow the instructions load his tune base map bam! Start it. It's tuning that can be a bear. The plug and play unit is ms2 extra works with tuner studio which allows you to use auto tune. You drive it tunes each cell depending on "weight" which is basically fuel load to where you set your afr table. I would say anyone could tune a car with this program.
It's pretty much the Mac daddy!!Last edited by Flyin4stroke; 02-19-2013, 07:29 PM.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
Only downfall for me is that i wanna go coil on plug, so a plug and play unit is out for me, but I know a guy who will build one for me to what I want
