Thoughts on building a drag car...
  • #31
    Now you have a project Brad lol
    -M3NTAL MARK! Woo!!
    • #32
      is it official or what?
      1991 blue L, 5 speed.
      1988 red L-plus-all stock.
      • #33
        Re: Thoughts on building a drag car...
        Got an itch to build this car. I have most of the ingredients just no time or space
        91GL BP/F3A with boost
        • #34
          I hate winter.
          Trying to decide on which flavor of Stratified's PNP ECU I should go for...the one for the EGT or the plain universal one or? I'll be running a festiva harness...
          • #35
            BP ECU's and the B3 ECU uses the same connector, I thought you knew that lol
            • #36
              I do know that. However his universal ECU is $450 and the EGT specific one is $575...the universal one has the same connection just doesn't come preloaded with all the same stuff.
              Have you seen Stratified's product lineup?
              • #37
                I haven't looked at stratified's site in a long time
                • #38
                  Isn't MS much cheaper, there must be a reason why your going with stratified.
                  • #39
                    Stratified IS MS. Just set up to be pnp replacement for Mazda B and K engine cars.
                    • #40
                      O, ok
                      Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
                      • #41
                        The only Ms that's cheaper is a DIY kit...and I don't wanna do that
                        • #42
                          Ya those DIY kits confuse the hell out of me, it's well worth buying a pre-built unit lol
                          • #43
                            Yes and Lex provides support himself until your car is running. No need to worry if I soldered a resistor the size of a flea wrong.
                            • #44
                              Yeah if you go with the plug and play unit you won't need lex. Mine was running instantly. Follow the instructions load his tune base map bam! Start it. It's tuning that can be a bear. The plug and play unit is ms2 extra works with tuner studio which allows you to use auto tune. You drive it tunes each cell depending on "weight" which is basically fuel load to where you set your afr table. I would say anyone could tune a car with this program.
                              It's pretty much the Mac daddy!!
                              1989 Ford Mustang GT 5.slow
                              1996 Ford F-150
                              • #45
                                Only downfall for me is that i wanna go coil on plug, so a plug and play unit is out for me, but I know a guy who will build one for me to what I want
