Originally posted by nitrofarm
Festicle and xaero
Can I have that part number?Originally posted by nitrofarm View PostI have a good alternative KYB pn If you want it. They are shorter and easily available through eBay for only $ 33.00.
Sent from my USCC-C6721 using TapatalkBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Originally posted by william View PostNitro is it for the mk1? I was leaning towards 1990 vw cabriolet.
That's what advanced dynamics recommend for my application.Originally posted by shadetree View PostMore info pleaseHere you go guys,the bottom mount is a no brain er. But you have to make a Hat for the top ( Or work with the Black Magic Conical Hats). Don't try running the short shocks until you lower the fronts at least 2" though.Originally posted by Festevil3 View PostCan I have that part number?
KYB 343191 was orig ride quality for 90-95 Corrado
Ext L =25.04,Comp L= 16.65, 8" Stroke
KG9130 was "Increased Performance" strut for
90-95 Corrado curb weight 2,668–2,809 lb
Ext L = 25,Comp L= 17.32, 7.83 stroke
KYB 341007 Excel-G Strut was OEM 83 VW Rabbit @ Amazon $33
This is what I have now and they are working ok with 120 lb Black Magic Springs on my Aspire. Once I lower the front another 3/4" I'll switch over to 170lb in the rear.
Ext L = 21.1 Comp L = 13.39, 7.72 Stroke
Monroe equiv = 71202
KG9105 is what I had and they worked good,but expensive...
Cant find any info that says they were oem on any car??? These are what Charlie recommended.
Seemed like they had slight MORE dampening than KYB 341007.
Ext L = 21.0 Comp L = 13.93 7.12 stroke
Nitro-
ps Dont even waste your time with the Monroe's OMG terrible-Last edited by nitrofarm; 10-02-2014, 07:39 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
First picture is cable clutch bracket with mustang cable. Pictures of routing dual cables for the disc brakes swap. This is the first festiva with FULLY functional disc brakes with parking brake! We used all escort gt parking cables fit like it was oem! Had to add a hold down bracket in the car. The egt cable fit the handle with out mods.
Festicle and xaero
LOOKS BAD ***, Keep up the good work !
Ninja edit for languageLast edited by Damkid; 01-28-2015, 05:55 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
