ok so this garage will be dedicated to the festicle and xaero_81 old b6t festiva. The festicle was starting to burn oil and the body is a little to race car for me. So I bought Donny's festiva which he started doing a nice b6t swap on. I was planning on parting the festicle out and putting the semi built motor into Donny's car. Well my buddy Dan caught the festiva bug and decided he wanted to buy it and own a turbo festiva.
Mods list for Festice
stock b6t
rocketman ECU
EGT g25mr
full Alston race cage
323 bf A control arms
civic coil overs
civic/del sol radiator
probe intercooler
fuel safe cell
Wilwood master cylinder
capri xr2 knucles
egt calipers
Galant rotors
xaero_81 festiva
Weisco pistons
Cat rods
ported polished miata head 1+mm over sized Super tech valves and springs
mx-3 custom intake with sheet metal upper
Fidanza cam gears
webb cams 505 cams
Boundary Engineering oil pump
ebay stage 3 clutch and lightened flywheel
AEM EMS pnp for miata
Kia trans w/straight cut 3-4 PAR gears, has plate mod (ferdis old trans)
LSD Mfactory diff
Toyota COP set up
EBay FMIC
BMW VTPS sensor
miata daisy rims
aspire swap
GarrettGT2560? Tag is missing seems to be a Ball Bearing not sure on trim
Tial wastegate
Things need to buy
Shocks/struts
coil overs
sump for gas tank
fuel pump
IAT, EGT, sensors
Jeep idle air controller set up
material for turbo manifold
material for custom A control arms
Clinton a former FF member who has built numerous turbo festivas is in charge of the fabricating, wiring and tuning for both Festicle and xaero_81. Yea we took the lazy way out but he know the wiring like the back of his hand.
Festicle custom tubular cross member to fit KIA G/ G25mr trans
Mazda 323 bf arms installed (Clinton's fabrication work)
random festicle shot
cross member
mystery T25 Garrett for Xaero
Cat rods compared to my K1 rod (for bpt)
stock b6t
rocketman ECU
EGT g25mr
civic coil overs
probe intercooler
fuel safe cell
capri xr2 knucles
egt calipers
Galant rotors
xaero_81 festiva
Weisco pistons
Cat rods
Fidanza cam gears
webb cams 505 cams
LSD Mfactory diff
Toyota COP set up
EBay FMIC
BMW VTPS sensor
miata daisy rims
aspire swap
Tial wastegate
Things need to buy
Shocks/struts
coil overs
sump for gas tank
fuel pump
IAT, EGT, sensors
cross member
