I see what your doing there
My 91 AWD protege
^^ya im keeping the car driving lol
So I grabbed my blown USDM AWD trans to put on a KL, the diff lock motor definitely interferes with the exhaust manifold and there was a minor clearance issue around the axle location
So I took off the USDM trans, brought out the grinder and did some clearance work on the engine.... Then grabbed a GTX trans and got the trans tight to the engine
Much better fit without the diff lock motor
And it's very tempting to buy the adapter plate after the holidays and make this happen
Vice grips were only there to make sure the trans wasn't gunna fall off lol
How much does all that weight? Thats a whole lotta engine & transmission. I like it though! Looks like it should work, if you can sort out a starter solution.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Hole in the top of the bell housing for starter location, it'd be very simple with how the adapter plate is setup
The plate comes with a piece that bolts to it for the KL starter to mount to... The miata trans needs a clearance hole in it for the starter just how the AWD trans would.... So literally just clock the starter mounting point around to match the top of the bell housing and done
And sorry, no idea on weight, I don't have a scale nor do I care enough to wanna get a scale lol
We had a lot of snow fall yesterday.... This thing is unstoppable in the snow and so easy to control while driving sideways :evil4:
I love this thing haha
Yes Chris more vids yo-Greg
Redneck Engineer
FOTY - '09
Yesterday on my way to work, I hit some black ice and basically drifted around a bend but half off the opposite side of the road and before I could get the car under control and back on the road again, I hit some reflector signs
Here's the aftermath
Don't mind my door seal hanging out lol
