Ian's B6T Festiva build
  • #16
    awesome work ian, keep it up
    Mike, AKA the sasquatch
    • #17
      Had an hour or so to spare this afternoon so did one of those little jobs on the project. When the car arrived the key was broken off in the ignition. Remembered I had purchased a complete set of locks from Junspeed quite a while back so I dug up the package and installed the brand new ignition lock along with the matching driver's door lock. The lock for the hatch and passenger door will go in later. I also have brand new Kia Pride steering column covers to go on but those will wait 'til later as well.
      Ian
      • #18
        I think your festiva is gunna end up looking a LOT like mine
        Looking forward to more progress
        • #19
          looking good!
          • #20
            Not much but here's a couple of Elias' photos of the new ignition lockset....
            Ian
            • #21
              Quick little update: another piece of the puzzle has arrived
              This will allow me to crank up the boost on stock turbo, injectors, etc. without having to upgrade to a wide-band O2 sensor.
              Now to find a boost gauge and manual controller
              Ian
              • #22
                very nice i think thats what festevil3 runs on his car(festycul) & he can go up to 18lbs!
                Never Hire a Boy to do a Man's Job!!
                • #23
                  I had a reich ECU in my 323 GT, pretty much the same thing as the Rocketman ECU
                  • #24
                    Looking good Ian
                    93-1.6l
                    f.s.- fms bodykit.
                    • #25
                      Thanks. Did some clean up in the garage today. I'very been given an old stick welded so I had to make room for it. Still have to wire up a plug for it.
                      Also made a couple of quick measurements on the transmission. The G series is about 1 7/8" longer the the E series which is about the same distance from the end of the E series to the nearest frame rail.
                      Won't be doing too much on the project for a bit here as I've picked up quite a lot if new clients in the last week or so. That in itself is a nice problem to have
                      Sent from somewhere west of here via Tapatalk!
                      Ian
                      • #26
                        Good stuff so far, lots of fresh toys to play with!
                        2008 Kia Rio- new beater
                        1993 Festiva- Fiona, DD
                        1997 Aspire- Babyspire, DD
                        1994 Aspire - Project Kiazord
                        1994 Aspire- Crustyspire, RIP
                        • #27
                          Love the color scheme......
                          -Greg
                          Redneck Engineer
                          FOTY - '09
                          • #28
                            Thought you might!
                            Ian
                            • #29
                              Not too much to report as I've been blessed with a ton of work. I have arranged a trade of some Festiva goodies for a pair of transmission mounts.
                              Quick question... can the stock passenger mount be removed from the engine without removing the water pump? Not too worried about it as I will be replacing the water pump anyway.
                              Ian
                              • #30
                                Yes it can be, but the timing belt does have to come off the top
                                1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
                                Rocketchips!
                                Bolt-on Weber Carb Adapters!
