I didn't want to install my struts or remove my brake lines.
So I used a jack beneath each drum location
Then the jack right in center of the beam on that tab sticking out.
I loosened the bolts and used the jack to maneuver up and down.
I slid everything back to pull the assembly off the hinges.
Then I proceeded to use a 2 jaw puller to press it out from the inside.
I know, using a puller to press lol.
I made sure to silicone lubricant spray then up underneath the edges to help the removal process.
It worked great. No problems at all.
Then once done with removal.
I took the new bushings and sprayed them with the silicone lubricant as well as the bushing hole.
Then I used the 2 jaw puller to press them back inside.
Once done I slid the beam assembly back into place and bolted it up.
Making sure to reuse the white nylon washers on the side of each bushing.
Now I'm just waiting on nuts and bolts to get everything buttoned up.
Here are the old bushings.
I am suprised how good of shape they are in.
I would rate them at 7-8/10.
I didn't plan on saving them.
So the puller pressed a couple lines into the bushing shafts the first 1/16" maybe.
They are still useable if anyone wants them.
Figured out after I was done how good of shape they were in.
If anyone wants the used rear beam bushings $10+ shipping so approx $15 and I'll throw in those used front sway bar to frame bushings too.
I'd rate them at 5-6/10 simply because the cracks on the outside edges extending inward maybe 1/2"
