That's evap...junk
Chris's Lifted BP swap
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
That's the evap.. should have had a vacuum line over to the solenoid on the firewall?2008 Kia Rio- new beater
It has the evap on the firewalll but a nipple is busted off so I hurd its fine with out the thang so ill just take it off and the big vacume nipple right under the throttle body where does that go?Last edited by Micro Mudder; 07-18-2013, 12:47 PM.1993 festy "white stallion" BP swap with 7" lift, 1ton wench
R.I.P. 1991 festy "the festiva" stock b3, atv bumper, 8' whip
Went to the junkyard and found a gt escort so I took some picks of how stuff goes and I took the vaf the one festy they had there had ac so the mottom pully wouldn't have worked.... but with the vaf on my car now it doesn't run so what's screwed up?1993 festy "white stallion" BP swap with 7" lift, 1ton wench
You need a BP VAF and ecu. Don't know what else, what's it doing?Last edited by zoom zoom; 07-18-2013, 02:59 PM.2008 Kia Rio- new beater
It should start up for a second and die without a VAF, sounds like you have exactly the opposite problem! Check over the swap thread and make sure you didn't miss anything.2008 Kia Rio- new beater
Yea I may just take the vaf out if I don't need it haha make it cleaner looking in the engine bay but ill look over the build thread but sime wires I didn't know where they went so I kinda just guessed haha1993 festy "white stallion" BP swap with 7" lift, 1ton wench
Yea dude you can't delete the VAF without going standalone.2008 Kia Rio- new beater
Looked today and it starts after about 20 seconds of it cranking over then it revs up then idles normal then just puts out and if you hit the throtle it dies enstently. I also got vacume line plugs! Not the colorfull kinds thow..1993 festy "white stallion" BP swap with 7" lift, 1ton wench
Weight you said I need a escort gt ecu what's wrong with the stock festiva one I thought you could use that... or is it different then the ecm I think I'm missing something here1993 festy "white stallion" BP swap with 7" lift, 1ton wench
fuel maps will be way different, your going from a 63 horsepower engine to a 130 horse engine. you have to have the bp electronics or the car will not run right, and if it runs good enough to drive it won't be putting out as much power as it should. The issues seem like they are probably due to the VAF in general. The car should NOT run if it's not plugged in and hooked up to the throttle body, granted it should fire up for a split second then die. If you have used or are using ether the only thing making it run is leftover fumes. You need to go back through and figure out what went wrong and where. Vacuum leaks will also cause the car to do funny things so get all open ports plugged before you try to fire it up. If you keep trying to make it work without things hooked up properly your probably gonna do some damage to the engine before you even get to drive it.
This is why my BP swap is taking so long, aspire wiring is so different the entire car had to be rewired. At least with a festiva most of the stock wiring can be used.Last edited by zoom zoom; 07-19-2013, 08:26 PM.2008 Kia Rio- new beater
Okay I got it to it only runs with the vaf now but still dies when you tap the gas so I'm going tto have to get the ecm of the escort gt cuz my ecm says b376 and nothing is hooked up wrong for what I checked over and over again soany thang I need other then an ecm cuz the whole car is there what else should I grab of it?1993 festy "white stallion" BP swap with 7" lift, 1ton wench
but ill look for the problem tomorrow and anh other thangs I've missed
