have put my build on hold cuz its hard to get parts with out transportation soo I bought a motorcycle so I I can go buy pparts makes sence to me haha but ill buy every thang next week including a welder to make motor mount, eeexhoust and all the other odds and ends
BUT I had an idea for the cold air intake, I'm going to put a real hood scoop on , reason because I'm going the have the huge cold air intake center of the motor facing the frount with a 3 way pvc valve the main goes to the throttle body. Then the throttle boddy and the other secondary I can have it directed to the inside of the car through the opening on the ppassenger side above the shock towerr so it won't. Flood the motor when I go through water sry if it don't quite make sence ill get it built and ill post it but I lade out the pvc pipe and it looks sick but to build it its like $100 not to bad for a ajustible 2 way air intake
but I will but can't check till I get the ecu hope I find one soon
