Originally posted by sketchman
Matthew
And that will not be happening. eth.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
^I wouldn't expect it would.
Someone else mentioned chipping in for another run after some de-kinking. I'd be in for that if you do go that way.Last edited by sketchman; 12-05-2013, 09:38 AM.Any difference that makes no difference is no difference.
IF stock B3 crank HP is 63, minus 15% friction = 9 for a total of 54 wheel HP. I gotta say, 71 seems totally unrealistic.Originally posted by Zanzer View Post.....seeing as my basically bone stock B3 put down 71hp on a cousin to the Mustang Dyno.....90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Also considering we have no 1:1 and 4th is 0.861:1 you could theoretically be seeing 14% under reality. That's already 104.5whp, and the ideal scenario goes up to 119.7whp. Obviously I'm way off in theoretical land, but still.Any difference that makes no difference is no difference.
I believe his compression is already at 11:1Originally posted by bhazard View PostThat's a 100% increase. Bump the compression up to 11:1, a little boost and e85 on megasquirt...250+?
I bet there's a lot of power left on the table running on the stock ecu.
Go standalone and let's see its true potential.Last edited by rmoltis; 12-05-2013, 11:01 AM.
Just had a long chat with Matt. Long story short, the shop guys didn't know how to operate a dyno. No inductive pickup on #1 plug wire (which would have given the tach signal they needed!), no fans in front of the car, they weren't even gonna raise the hood, but I did it anyway.Originally posted by rmoltis View PostI believe his compression is already at 11:1
Also, the cam in Matthew is a turbo cam, which makes very good torque as opposed to peak power. If anything it might be a quicker cam in the 1/4 than a peak-HP cam, and is certainly very daily-drivable. Matt dynoed it up to 6K RPM, not wanting to hit the fuel cutoff, but says the HP numbers were still climbing at that point. This is what I felt too, when I did a roll-on with it. So getting rid of the fuel cutoff via MS or some other standalone would be a good thing.
Not sure what the compression is. Hafta axe him.
Edit: Matt also said that running it in 3rd gear would have been better; and that I couldn't just pump in E85, I would need either larger injectors or 85 PSI for the stock injectors, or I'd quickly kill the motor with a too-lean condition.Last edited by TominMO; 12-05-2013, 11:15 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
If the HP numbers were still climbing, I'd want an adjustable cam gear stat.Originally posted by TominMO View PostAlso, the cam in Matthew is a turbo cam, which makes very good torque as opposed to peak power. If anything it might be a quicker cam in the 1/4 than a peak-HP cam, and is certainly very daily-drivable. Matt dynoed it up to 6K RPM, not wanting to hit the fuel cutoff, but says the HP numbers were still climbing at that point. This is what I felt too, when I did a roll-on with it. So getting rid of the fuel cutoff via MS or some other standalone would be a good thing.1989 Carby L: Stock. Slow.
1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
2016 Focus ST: daily driven go-kart
By an amazing coincidence, I just happen to have one of those! But in my experience with Matt's MPG cam, the middle of the sweet spot turned out to be with the cam gear at zero, so I'm not too sure we would get much if any more out of Matthew by turning the cam gear; and at $75 a pop, that's expensive tuning!Originally posted by DON SVO View PostIf the HP numbers were still climbing, I'd want an adjustable cam gear stat.
I'm more inclined to going with a standalone and a dual-core radiator, to control heat at the higher RPM range.Last edited by TominMO; 12-05-2013, 11:33 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
You guys are making me want to go dyno my car in third....I bet it would make some big numbers too-Greg
Redneck Engineer
FOTY - '09
Tom, sounds like you need to get Matthew into a better shop in the area. Those guys didn't seem to know what they were doing! I've always seen fans running during dynos. And yeah, I would have thought they have some way of gauging rpm without tapping into the system or something. Like the inductor coil thing Matt was talking about. Sounds like you need to find a better shop. I'd gladly give you 5 bucks to hit another dyno with it. I'm sure a couple other members would pitch in too.
