Originally posted by TominMO
Matthew
If Matt's original dyno graph is correct ("horsepower climbing at fuel cutoff"), then the cam can be retarded to bring peak torque down lower. This will give a broader power curve and bring the peak HP number into reality. Food for thought.1989 Carby L: Stock. Slow.
1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
2016 Focus ST: daily driven go-kart
Matt sez you can do more with a B6 than a B3. Not only more displacement, but a better head design too.Originally posted by bhazard View PostDon't get me wrong I love my swap, but I'd be more impressed at a "stock engine" doing the same thing.
I wonder what a nice b6 bottom end would do here?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Point taken. Matthew has lots of torque already tho. I could take my adjustable gear down with me to FL when I go visit Greg. Then when we dyno it, I can try a little retarding. I'll check with Matt first tho, as he may have fooled with this already, or he might tell me not to waste my time.Originally posted by DON SVO View PostIf Matt's original dyno graph is correct ("horsepower climbing at fuel cutoff"), then the cam can be retarded to bring peak torque down lower. This will give a broader power curve and bring the peak HP number into reality. Food for thought.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
We shouldn't get any more retarded around here than we already areOriginally posted by TominMO View PostPoint taken. Matthew has lots of torque already tho. I could take my adjustable gear down with me to FL when I go visit Greg. Then when we dyno it, I can try a little retarding. I'll check with Matt first tho, as he may have fooled with this already, or he might tell me not to waste my time.
In seriousness, the torque is there already, it was decided by all the airflow mods done by Matt. The cam gear can help move it around to produce more useful power, power that's under the curve (and before 6,000rpm).1989 Carby L: Stock. Slow.
Different strokes for different folks!Originally posted by bhazardGaskets is not a rebuild. Matt rebuilt everything.
I'd honestly rather have the 8v engines. Therefore, a b6 makes sense to me.1989 Carby L: Stock. Slow.
Originally posted by TominMO View PostIF stock B3 crank HP is 63, minus 15% friction = 9 for a total of 54 wheel HP. I gotta say, 71 seems totally unrealistic.
I said "basically" bone stock...i.e. it has no mechanical mods or power adders such a boost or giggle gas
Also, I have the dyno graph and video to back it up. Not to mention at least 4 other forum members who were there during the run. So you can apply your optimism to your car but not mine only because I don't charge $200 for a reground cam?
Car looks great, and made awesome numbers Tom, congrats.
Is the car more rusty, than Larry? I see your making it comfy too, those are the best mods. Feel them all the time, not just when your wide open.-Greg
Redneck Engineer
FOTY - '09
"Bone stock" means stock. When you modify that by saying "basically", you now mean it's not bone stock. So what have you done to it? If you hold back info, we can't have a meaningful conversation.Originally posted by Zanzer View PostI said "basically" bone stock...i.e. it has no mechanical mods or power adders such a boost or giggle gas
Also, I'll bet it's an apples-and-oranges situation with the dyno. Which one did you use? Then there's operator skill and how it's set up. I'll bet a Dynojet like the one at the facility near Greg (Beach Dyno) will give me better numbers. Plus those guys actually know what they are doing.Last edited by TominMO; 12-05-2013, 01:06 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
He meant "LS1 stock".Originally posted by TominMO View Post"Bone stock" means stock. When you modify that by saying "basically", you now mean it's not bone stock. So what have you done to it?1989 Carby L: Stock. Slow.
LOL
That's a dog LS1. Down a few cylinders, I take it. Like 6?Any difference that makes no difference is no difference.
Larry is actually pretty rust-free, just very minor stuff. Not so much with Matthew. I have addressed the rust in various ways, depending on the location. Spare tire well rust was superficial and responded nicely to sanding and painting. Rear wheelwell rust was cancerous, so I used aluminum sheet, stainless fasteners, spray-can rubber sealer, and flat-black paint to solve those issues. Not what a body man would do, but very functional. The only place I have left to address is in front of the driver rear wheelwell. None of the rust issues are in the major structural category. But I do need to look at the lower rad support area. With greater-than-stock power, it's even more important to make sure this does not flex.Originally posted by eurotiva View PostCar looks great, and made awesome numbers Tom, congrats.
Is the car more rusty, than Larry? I see your making it comfy too, those are the best mods. Feel them all the time, not just when your wide open.Last edited by TominMO; 12-05-2013, 12:58 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Very true. Just curious about rust for the long term, I know at some point you'll decide to keep one or the other, but I think you should keep both. I'm also curious of the mpg of the mighty b3. Should still get decent mileage.-Greg
Redneck Engineer
FOTY - '09
No question I'm keeping Larry. So then the issue is, do I need two similarly-equipped fast Festys? (Since Larry will be upgraded.) I'm considering having you install an F tranny so I can get a better clutch, then have Matt do his thing with the B6 head, cam, intake and header. He is talking about well north of stock BP power with an NA B6. Believable, considering where Matthew is. Like Brad, I am a fan of the "small-block" Festys! Selling Matthew would finance Larry.
Also, I could pull the fun parts off Matthew and install 'em in Danny; then put a stock B3 head on Matthew and sell him as a nice DD, with Matt's header as a bonus (since Danny already has a new DAE B3 header).90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
