Originally posted by eurotiva
hartstiva
I put in b6d fuel injectors and turned the base pressure down. I needed 20lbs for those injectors to mimic the flow rates of factory festiva injectors. I'm going to be running a 5-6 to 1 ratio fmu which is made for bigger injectors than factory. Since my aem fpr could only go to 24lbs of base pressure I'll mix my fuel before hand with e85 so it's leaner amount of fuel.
I put in a bigger fmu disk today, was running the 3:1 now 7:1. I wasn't getting any pressure rise before, and in still not. I hooked the air hose up and blew into the fmu and my fuel pressure gauge spiked, 90+ psi. But when I'm driving, I can get my boost up to 4 or 5 before it goes to missing, and my pressure isn't rising, what's up? Frustrated
Where is your boost line connected? Is the port plugged?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Dumb question, but I gotta ask. You don't have a check valve in the signal line do you?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
No, if your gauge is reading boost then your fpr should be as well.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
So it made it up to 8lbs of boost today. Still seems to not be gaining ample fuel pressure from the fmu. I'll probably pull it apart this week and see what kind of problems it has, do some out of vehicle testing with it. It's such a let down going from turbo b3 to na b3. You'll be driving and apply partial throttle and keep waiting for that boost to pick up, and it never does
Use a multimeter to test your TPS. I didn't know the Festiva had the variable resistor type TPS. That could definitely be worn if that's the case.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I don't think it has a variable type resistor.
Edit:
It reads idle, wot, or neither.
It can come out of adjustment though. The little gear is made of plastic, mine was wore out enough to have quite a bit of slop. Pop the cover off and you will see what I mean. The way to calibrate it is in the fsm. If you need me to I can snap a photo and post it.Last edited by Chobobulous; 03-23-2015, 01:52 AM.
If you could that would be great,Originally posted by Chobobulous View PostI don't think it has a variable type resistor.
Edit:
