Nice score!
hartstiva
Had anyone here done an obd2 swap before. I'd be totally brave enough to tackle a project like that. But it'd have to be worth it in my mind. Like oem ecu tune capability, like gm had on all their obd2 ecus with hptuners.
Sent from my SGH-T989 using Tapatalk
Hartstiva has been having intermittent starting issues. I found the ground bolt from the head to the chassis to be 6 turns loose and the strut pillar was painted. That doesn't work. Battery to chassis wire was rusted. Main fuseable link was all kinds of gross. What do you guys do with those fuseable links. Rewire with actual fuses?
Replace with cartridge fuses, typically recovered from a JY visit, but available new from nearly any McParts place.Originally posted by bhearts View PostMain fuseable link was all kinds of gross. What do you guys do with those fuseable links. Rewire with actual fuses?
Make sure they are the "long legged" ones
Let me see if I can find a pic.
If need be I can send you some, if you drop me a PM with your addy.
These are the amperage and order you need them in:
Pink/20 Amp Green/40 Amp Pink/20 Amp
See pic.
Last edited by Pu241; 05-20-2014, 08:42 AM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Type for a once every twenty years wire wheel cleanup job.
Guaranteed to start first time, every time.Last edited by bravekozak; 05-20-2014, 08:38 AM.
stripped o2 threads. I used this custom made end cap and some safety wire to really get it in there snug. Put high temp silicone on the thread to seal it up. It was pull out loose, now I can't even get it to budge. I guess this could make a decent quick fix for someone in this predicament that doesn't have a new manifold on hand
what's this hose. It has oil in it. Looks like it comes from the oil pressure sensor deal
