Im gonna make a intake out of PVC pipe i think.... i need to measure my throttle body and MAF. i think its 2.5inches.....
» TheGageinator's 1996 Aspire Build thread!
Did more work today. I Removed my resonator and put my exhaust back together. I also starred on my new Intake made of 2inch Inside diameter pvc pipe.
What do you guys think about the intake?
Ps I will try to get a high flow catalytic converter soon. The exhaust sounds really echoey when accelerating.1996 Ford Aspire 105kmiles
got my Miata wheels today woohoo! they have some 185/60/14 tires in really good shape. pics tomorrow
the Miatas came with the lightest factory wheels ever. they had some that weighed only 9lbs. those are exspensive. The ones i got are 10.8lbs eachLast edited by TheGageinator; 08-25-2014, 08:49 PM.1996 Ford Aspire 105kmiles
I figured out what the fuel smell was in my car. I opened up the fuel neck cover ad saw that 2 of the smaller EVAP lines were cracked wide open. I replaced ALL the lines with some 1/4inch fuel line. glad my filler neck wasnt bad!
take out the back seat
pull up the carpet to avoid possible fuel spillage
Remove plastic panels
remove all 10mm bolts holding down fuel filler/EVAP cover
remove 2 bolts retaining the EVAP solenoid and canister. makes it easier to get to the lines
new lines!
