Ouch! sorry I was late, just got back from the track ):
BP-turbo automatic build
Plumbed radiator, filled cooling system with water and rad flush. No leaks there or in the trans lines.
Rigged a BP heat shield onto my exhaust manifold.
Worked on charge pipes. Switched some stuff around, now its 2.5" out of the turbo and into the IC. Need a new elbow at the IC inlet. I don't trust that one.
91GL BP/F3A with boost
This area has me a bit concerned. Did you have the water pump inlet hose so close to the downpipe before?Originally posted by bhazard View Post
Herpderp. Replied to an old post about the vacuum modulator:
It's a solenoid to push the shift valve. Purely electromechanicalLast edited by crazyrog17; 05-12-2015, 05:45 PM.-Zack
Neon SRT4 i/c ?
Still some things to do. Need to make a tray and switch to my AGM battery. But I buttoned it up today and took it for a spin. Only around 7 psi I think but it hauls good.
Glad you posted here Brad. Its a lot better to see the pics. Nice job!Dan
In case you missed it...the link is kinda hidden in there between the pics.
