The inner control arm bolt has a broken captured nut? Ugh, this is a bad thing. This requires surgery.
Meepersly's 88 festiva build.
Sadly yes. Thankfully the welding room in the shop will be open by the end of the month so I can cut and ask a guy who welds to weld it back. I'm going to get a new bolt for the inner control arm. So the swap is on hold while I wait for new tie rod ends (needs new ones anyways) and the welding room to be opened.88 Ford Festiva LX "Miogi" B8-ME swapped.
93 Ford Festiva L "Haywire" Rat infested trashcan WIP
I wish I could have answered this sooner. I usually undo the strut and sway bar bolts at the hub then push the axle into the trans and very quickly pull straight out. May take a couple tries but usually works first time.Originally posted by Meepersly View PostProgress check. Rear main seal replaced and transferring some b3 parts onto the b8. Also tearing apart the festiva. Anyone know an easy way to pop the CV axles out? Mine are really well put in there. Last time I pulled CV axles I used a pry bar.[ATTACH=CONFIG]18654[/ATTACH]
OK got some parts still got to do the surgery still waiting on some new tie rod ends to come in the mail, but oh well going to work on the festi tomorrow and add my new parts. Pulling the engine back out and thinking of painting the engine bay. Any ideas on colors? At first I thought black, but that seems too dark for an engine bay.
got a rear wiper, sprayer and pump going to install that too eventually. I also got a keyless locking system with actuators. This will be nice so when I want to get in I don't have to worry about scratching the door with my many keys.Last edited by Meepersly; 10-19-2015, 09:37 PM.88 Ford Festiva LX "Miogi" B8-ME swapped.
I like the silver, you should stay with that.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
yes but it is stained by the old coolant that was in the engine and has an ugly orange and brown in some parts that wont wash off. Should I get a rattle can of silver and re-paint it?88 Ford Festiva LX "Miogi" B8-ME swapped.
You can probably find a close match to the original color. You'll probably want to clear coat it as well with a quality clear. This will make it easier to keep clean and protect the paint. Silver doesn't hold up well to engine fluids without a protective clear. I like duplicolor clear engine paint. Once it fully hardens (this takes a month or more) it's quite resistant to oils and such.Last edited by Advancedynamix; 10-20-2015, 12:05 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
No, you'll want an automotive paint. There are lots of different color choices of duplicolor products, to match your car.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Had another go at cleaning the engine bay. wow just needed some elbow grease and some degreaser.
Before: https://goo.gl/photos/Mcr6pFC6MaheFPPK9
After: https://goo.gl/photos/muB8q5XpVGVtdUq56
I only did the passenger half still have to take out all the junk in the way and get the driver's side.
more photos after more dis-assembly and cleaning.Last edited by Meepersly; 10-22-2015, 10:07 PM.88 Ford Festiva LX "Miogi" B8-ME swapped.
Finished cleaning the engine bay. Going to work on the engine and tranny and hopefully drop it in. Yesterday I extended the hole on the passenger side engine mount.
Also got some fog lights for the bumper
Progressing.... I also taped up my mess of a wire harness I had some more. I only had white electrical tape.88 Ford Festiva LX "Miogi" B8-ME swapped.
Started the 1.8L Festiva today but only for a little. dont have cooking and forgot the oil pan gasket leaks when it runs. Going to put a new gasket on, new cv axle, and many other things tuesday.
Last edited by Meepersly; 10-25-2015, 11:59 PM.88 Ford Festiva LX "Miogi" B8-ME swapped.
