A little expensive but if there's nothing good available aftermarket I can justify spending that much. I've ordered a few things from the local mazda dealer through work (wholesale pricing) and they've been cheaper than those online prices.
Just another build thread
True you'll never need new rings againOriginally posted by shorestiva View PostA little expensive but if there's nothing good available aftermarket I can justify spending that much. I've ordered a few things from the local mazda dealer through work (wholesale pricing) and they've been cheaper than those online prices.
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Here's part 1 of the bottom end assembly. I borrowed a sweet hone from work to clean up the cylinder walls. The cross hatching isn't a 45 but it'll do. I also cleaned up the internal parts in a super cleaner bath, seafoam bath and then a wd40 clean followed by cleaning with compressed air. I'm taking a small break to get some food and then I'll be putting everything back together. I am going to be reusing the old rings. They're in pretty good shape.
What grit stone on the bore hone?Trees aren't kind to me...
What was your ring gap? That's critical on these engines. Most aftermarket rings come out around .012", but I've taken apart 150k mile turbo engines with a .007" top ring end gap. Twice the gap on fresh rings is a big problem.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
AND....did you know or think about the fact that every .001" you increase the bore diameter you increased the ring end gap .003? I use honing only to finish a freshly bored cylinder to the correct size. And no I'm not the smartest guy on here, just one that has made a lot of mistakes in my early days. Now in my later days, fewer mistakes. Not to mention that I am more resourceful in fixing them.....LOL!:woc:'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
'93 Festiva L, 5 speed, Aqua, bought from the original owner,.Zero rust but very nasty otherwise. Awaits the B6T.
'91 Festiva L, 5 speed, bought to drive while putting the B6T in the '93. now B6ME powered.
I retained the stock rings. I didn't check ring gap and its all assembled now.
I think you guys think i opened the bore up a lot more than i did. The only thing i did was polish the cylinder walls.Last edited by dliverance; 01-23-2017, 04:49 PM.
An interesting bit on honing.....
I guess I'll be tearing it apart this weekend and checking the ring gap on the stock and new rings that I didn't use. I'll check it at 4 different depths of each bore and I might even clean up my other block and grab another hone. Sucks because I have to order another set of bearings but I'd rather be certain.
