Real quick Google search shows that some spec miata guys were buying rings for .010 over then filing them down. I think it makes the rings have more tension on them though. I'm sure charlie will chime in and tell us why this is a bad idea lol.
Just another build thread
I would suspect that it would put an odd twist to the ring, the inside diameter edge being pushed above or below the OD edge plane within the bore and causing excessive tention within the ring land.Trees aren't kind to me...
You don't need to replace the bearings unless you've scratched them. Pedro still has the original Main bearings because they were well within spec. No need to toss good parts.Originally posted by dliverance View PostI guess I'll be tearing it apart this weekend and checking the ring gap on the stock and new rings that I didn't use. I'll check it at 4 different depths of each bore and I might even clean up my other block and grab another hone. Sucks because I have to order another set of bearings but I'd rather be certain.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
This seems to work well, except the ring quality isn't good on aftermarket rings, so that causes problems.Originally posted by shorestiva View PostReal quick Google search shows that some spec miata guys were buying rings for .010 over then filing them down. I think it makes the rings have more tension on them though. I'm sure charlie will chime in and tell us why this is a bad idea lol.
The OE rings have noticeably more tension than the few sets of aftermarket rings I've purchased (NPR, Hastings).Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Yeah that's spot on with what Charlie said his were too seems like a aftermarket stereo typeOriginally posted by dliverance View PostI checked the ring end gap with one of the aftermarket rings that I'm not using. I used the same one to check all 4 cylinders and got .014, .014, .015 and .014. I'm going to check with an oem ring sometime later this week. If the oem rings are good, I'm not going to tear it all apart.
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
I would think that, as long as your bore is within spec, standard size should be fine.Originally posted by shorestiva View PostI'm going to ordering a set of factory rings soon should I get the oversized and file down or will standard size be fine?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
aren't you glad you checked? No you should have peace of mind!:happy3:Originally posted by dliverance View PostI checked the ring end gap with one of the aftermarket rings that I'm not using. I used the same one to check all 4 cylinders and got .014, .014, .015 and .014. I'm going to check with an oem ring sometime later this week. If the oem rings are good, I'm not going to tear it all apart.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
'93 Festiva L, 5 speed, Aqua, bought from the original owner,.Zero rust but very nasty otherwise. Awaits the B6T.
'91 Festiva L, 5 speed, bought to drive while putting the B6T in the '93. now B6ME powered.
What's wrong with the cross hatching? Be careful you dont take off too much material. .001 bigger hole (.0005) on each side will increase ring gap by .00314. I do admire your drive. Keep us posted! And my previous post should have read : now you should have peace of mind.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
I wouldn't worry about the hone so much then just clean up the rings and bore wellOriginally posted by dliverance View PostI considered that too. Worst case, i have a spare block with that i can use as well.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
I'm looking at vacuum manifold options for my carb setup. I found a cheap manifold with 2 large ports and 6 small ports. 4 of the 6 small ports will go to each of the runners, 1 large will go to the brake booster and now I'm stuck on what to do with the dizzy. I know there's 2 ports on mine but I'm not sure if both go to the same place. I'll have to look at it later. I also need to figure out if I can use the other large port for a catch can off of the vc. maybe go from the vc to the catch can then it will be drawn into the runners from there. Either way, I need to start figuring this out soon.
I dropped the head off today for clean and skim. I should have it and the VC back by Monday. I think I'll have the long block assembled by then. I still need to fit the distributor and rebuild the carbs. I also need to skim the flywheel from my old motor but I have to actually pull it first.
