Festiver build thread
  • #76
    This morning I was letting the engine warm up in my driveway. I thought the ground was flat. I let her in neutral sat for a second before getting out just to make sure she wouldnt roll. well after 7min of sitting perfect still while I was in the garage, she rolled forward.... Into the back of my dad's truck. Shattered the headlight lens luckily I have the red car to lend festiver a headlight.
    Sent from my XT1585 using Tapatalk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    • #77
      Originally posted by Festiver View Post
      ...and with the bp the power is great but the torque is even better roads id have to downshift twice and hold at 3500 rpm just to keep my speed up I can easily cruise in 5th at 2200 rpm with light throttle
      I have similar results with my B6T! With three adults and two storage bins full of dishes I didn't have to downshift on any of the hills between Edmonton and Calgary while maintaining 110-130kph (70-80mph).
      Ian
      • #78
        That's awesome! I cringe doing over 75 because I havent don't the 5th swap yet
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
        • #79
          I'm running with the stock E series transmission.
          Ian
          Ian
          • #80
            Ian
            With a b6t?! Wow didn't think itd hold
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
            • #81
              It's holding up fine. I have a stock flywheel, stock clutch disc and Spec Stage 2 pressure plate.
              Ian
              • #82
                I wouldn't worry too much about the rpms with the g series. I ran mine 80 85 from Newbern NC to salem il no problems yeah the rpm are up there but it won't hurt anything but fuel milege I only get 32-35 at them speeds.
                B6d+g I'm getting a 5th gear swap in a few weeks though! Should help with mpgs a bit . I get 35-42 depending on how much fun I have back and forth to work. I'm hoping with the gear swap I can get closer to 50 when I really try.
                • #83
                  I wish I was getting those mpg something is off with my bp swap I only get 22-24 mpg normally hoping it'll clear up with the new engine
                  Festiver
                  93 L find/5 speed
                  BP/g15mr swapped
                  89 festie
                  rustful
                  93 festie
                  advanced suspension
                  kai/skeeter camber
                  b3t/g15mr
                  • #84
                    Ok so I feel like I'm starting a new topic in general discussion every other day so I apologize. That just a bunch of things I want to talk about and or opinions on festiva wise but anyway exhaust notes nothing I love more than aggressive pops crackles and bangs when a car let's off the throttle now before someone says just go v8 I'm sticking to my bp lol
                    How does a 4 cyl get this angry over run exhaust note I've heard everything from large diameter pipe, straight pipe, over fuel tune idk what works with a bp when I had my 3" straight pipe it didnt crackle or anything the occasional backfire though so do I have to go microsquirt and tune a little more fuel in the overrun?
                    Festiver
                    93 L find/5 speed
                    BP/g15mr swapped
                    89 festie
                    rustful
                    93 festie
                    advanced suspension
                    kai/skeeter camber
                    b3t/g15mr
                    • #85
                      If I could have a festiva that sounded like this I'd be a forever happy man lol I just can't do the unreliable part
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • #86
                        it won't load but it was this video I recommend everyone listen to the end
                        Festiver
                        93 L find/5 speed
                        BP/g15mr swapped
                        89 festie
                        rustful
                        93 festie
                        advanced suspension
                        kai/skeeter camber
                        b3t/g15mr
                        • #87
                          Sequential fuel and spark engine management and set the softcut rev limit to do that. Also anti lag and traction control/launch control can be set up to sound like that. As far as the depth of tone, it helps that the Neon is a 2.4L. The 1.8 isn't going to be as deep.
                          • #88
                            The popping on the over run is done with your fuel and spark maps. I had mine set so it would do that. It's been a while since I played with that so I can't remember exactly what I did though lol.
                            Better Than Nothing Racing
                            Way too many cars
                            :woc:
                            • #89
                              After I go microsquirt I'll have to have it tuned anyway there's a world-class tuning shop less than 3 mi from me im a bit scared of the shunning I'll received for my "ricer" request but I don't care itll be worth it
                              Yeah I figured the displacement gave it the depth of tone oh well and I would love to play with the 3 step control but I'll need a beefy header before I go that extreme
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • #90
                                Microsquirt can support 4 logic level (5v) coils iirc, so you should be able to have sequential spark. You'll need to start researching which coils to run. I know GM coils are pretty popular.
