Sounds like the iac. Try unplugging it . You will probably have to turn up base idle after unplugging it .
I've nevery had a bp but my b6d was doing the same thing and it was the iac I haven't had it plugged in in 4+ years with no issues.
festiver finally meets her parking spot
festiver is doing very well had a hiccup with the shift linkage bolt but that's fixed and the upper rad hose started to pop off because I'm a dummy who forgot to clamp it but thats good too now just the hood pins (hood lock won't go back) also my thermostat wont open so that's ordered on its way also there's a whining only under throttle once I'm in 4th and 5th axle maybe? They don't seem that angled
