Festiver build thread
  • #46
    Also with the vaf adjustment my mpg is much higher I'm at 7/8ths tank which means usually 2 gal -2.5 gal and I did over 70 miles
    Sent from my XT1585 using Tapatalk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    • #47
      So my milage hasn't improved compression test showed the piston rings are worn out but oh well it runs well I'm happy so the intermediate shaft adapter plate bolts started to back out on the way home from NC 500 miles plus 130 miles of driving the adapter was all cracked and destroyed before I knew about it so rip that gonna try to make a new one in class out of steel
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
      • #48
        dual booty pic but got festiver back on the road not proud of how the adapter looks but it works welded it back to working order
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
        • #49
          found this picture today last year I bought festiver no regrets besides not buying one sooner lol update my lower radiator hose has this weird thing where it gets super cold at night and leaks but doesn't leak all day I need something else it's hella rigged any ideas? Bp swapped civic radiator I'll take pics tomorrow also festiver pulls right accelerating pulls left decelerating bearings are good and alignment is good idk what the problem is
          Festiver
          93 L find/5 speed
          BP/g15mr swapped
          89 festie
          rustful
          93 festie
          advanced suspension
          kai/skeeter camber
          b3t/g15mr
          • #50
            How does it leak when its cold but not when it's hot? That's pretty strange.
            • #51
              The pulling right on acceleration is normal torque steer, I'm dealing with the same thing in Skippy. Everything up front is good and tight. Talked to Charlie about it and bushing deflection seems to be the likely culprit.
              • #52
                Yeah its weird but in reality it's trash I gotta think up something different
                Festiver
                93 L find/5 speed
                BP/g15mr swapped
                89 festie
                rustful
                93 festie
                advanced suspension
                kai/skeeter camber
                b3t/g15mr
                • #53
                  Not really an update but the most annoying thing with festivas is that all the coolest wheels are 17"x8"+ and they won't fit without serious modifications to the front end but it's oh well the pros overpowered the wheel con 10000 to 1
                  Festiver
                  93 L find/5 speed
                  BP/g15mr swapped
                  89 festie
                  rustful
                  93 festie
                  advanced suspension
                  kai/skeeter camber
                  b3t/g15mr
                  • #54
                    What wheels are you talking about? I think the coolest wheels come in 15" sizes myself, still a bit big, but doable.
                    • #55
                      Fifteen52 tarmacs
                      everything by radi8
                      Rotiforms
                      I like deep dishes on race cars and stuff but on super clean cars I love that super flush clean look as why Im trying very hard to get those trans am wheels to work on ømëga might pick up a set of escort wheels too they look awesome
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • #56
                        these in a 16" would be beautiful
                        Festiver
                        93 L find/5 speed
                        BP/g15mr swapped
                        89 festie
                        rustful
                        93 festie
                        advanced suspension
                        kai/skeeter camber
                        b3t/g15mr
                        • #57
                          Check these out
                          Or Maybe These
                          • #58
                            Oo the first ones are really nice is it a good brand would I have to worry about cornering and pot holes with them? I know my xxrs are tough wheels for being cast reps
                            Festiver
                            93 L find/5 speed
                            BP/g15mr swapped
                            89 festie
                            rustful
                            93 festie
                            advanced suspension
                            kai/skeeter camber
                            b3t/g15mr
                            • #59
                              Not sure on the brand quality, but Festivas are so light that you'll have a much better rim survival rate than an e30 or mk2 VW. They are 15x8 so you'll be rim poking with 165mm tires and you may want flares. With 4 degrees of camber and the right spacers, they might fit.
                              • #60
                                True I'll be better off with the 15x7 though plus it's a challenge lol
                                Festiver
                                93 L find/5 speed
                                BP/g15mr swapped
                                89 festie
                                rustful
                                93 festie
                                advanced suspension
                                kai/skeeter camber
                                b3t/g15mr
