Festiver build thread
  • #61
    2nd bp only 3k miles all the seals seem in good shape but I have a gasket kit on standby gonna swap next weekend hopes are high with this engine
    Sent from my XT1585 using Tapatalk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    • #62
      also finally installed the tach cluster it's really nice to have
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
      • #63
        So I couldn't put the new bp in but hopes are for this weekend but new issue won't idle surprisingly will stay alive but bounces between 200rpm and 900rpm and this causes the alternator belt to slip, it becomes a mess quite embarrassing to be honest already checked for air leaks nothing. my o2 is cut from hitting the radiator (will fix that) for now my idle is at 1500
        this new engine has gotta go in this weekend
        Festiver
        93 L find/5 speed
        BP/g15mr swapped
        89 festie
        rustful
        93 festie
        advanced suspension
        kai/skeeter camber
        b3t/g15mr
        • #64
          Sounds like an air leak, or your idle valve has gone crazy. Unplug it and see if it stabilizes.
          • #65
            Turned out to be a sticky vaf wouldn't return fully problem is fixed now also my idle valve is deleted
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
            • #66
              some how they still fired the pic doesn't show how bad these were but they were worse then any fouled 2 stroke plug I've seen
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
              • #67
                That sticky VAF was probably causing a lot of your issues. Good catch! Also, switch to NGK v-power plugs.
                • #68
                  I was going to idk what happened just never got around to it. these are the plugs the engine had from the junkyard lol. I gotta readjust my vaf because before I realized the stickiness I tried to readjust well now it's all wacky
                  Festiver
                  93 L find/5 speed
                  BP/g15mr swapped
                  89 festie
                  rustful
                  93 festie
                  advanced suspension
                  kai/skeeter camber
                  b3t/g15mr
                  • #69
                    Why was it sticky? Did you let Bhaz get too close to it at madness?
                    • #70
                      Lmao nah because I've been running hoodless because bent hinges and the rain fell through the cut silicone(from me adjusting it) and ever so slightly rusted the shaft a little bit of pb blaster and some wiggling and it's perfect
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • #71
                        Today I was driving to the gfs house and there's some tight fun turns along the way. I try to keep myself from too much fun (don't want to crash) but I allowed myself to hit this one long bend at 70 mph (it was enough I had to push off the door to keep in my seat). I'm not sure why i was so focused on it but I felt the rear beam twist (as it's intended purpose, I didn't break anything lol). it was a weird feeling i could feel the rear ever so slightly turning unlike anything else I've pushed into a corner. It made the car seem so comfortable almost cocky at that speed. I've pushed festiver into corners before but never focused so much on how it moves it's actually quite an addictive feeling lol. I haven't found festivers limits and quite frankly I hope I never do lol
                        Festiver
                        93 L find/5 speed
                        BP/g15mr swapped
                        89 festie
                        rustful
                        93 festie
                        advanced suspension
                        kai/skeeter camber
                        b3t/g15mr
                        • #72
                          Dang man that sounds like so much figgin fun!! I have a bp just have to wait til I get more $$$ to do the suspension first then the swap. Envious
                          92 Festiva L - bp & hydro g, advanced coilovers, aspire brake swapped
                          • #73
                            This makes me smile.
                            • #74
                              Lmao it was fun and I really need to move to coils too I'm running cut springs (don't) hopefully I can go to coils by February and with the bp the power is great but the torque is even better roads id have to downshift twice and hold at 3500 rpm just to keep my speed up I can easily cruise in 5th at 2200 rpm with light throttle
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • #75
                                it's crazy how addictive it can be. I gotta stay calm though before I get myself into an issue lol. can't wait to get festiver on a track, but sadly all my local autoxs don't start till like April
                                Festiver
                                93 L find/5 speed
                                BP/g15mr swapped
                                89 festie
                                rustful
                                93 festie
                                advanced suspension
                                kai/skeeter camber
                                b3t/g15mr
