Festiver build thread
  • Originally posted by dliverance View Post
    That sounds awesome and also, the trees there are pretty cool too.
    Lol Pennsylvania in the winter
    Sent from my XT1585 using Tapatalk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
      Also thats what a full 3" exhaust system sounds like on a b3 with 240k miles
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
      • People have had problems when the VAF wasn't mounted flat and level.
        It's coming along nicely!
          I've heard about that I was hoping that with the vaf pointed down it would act as I'd it just had more spring tension so me reducing spring tension slightly would give it the same effect still runs great so idk we will see but thank you
          Festiver
          93 L find/5 speed
          BP/g15mr swapped
          89 festie
          rustful
          93 festie
          advanced suspension
          kai/skeeter camber
          b3t/g15mr
          • That makes sense.
            • so this happened the other day got the header off and got all the studs out yesterday but should I go for "automotive studs" or just do 10.9 bolts with the heads cut off and ground to the nice thread start
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
              • So I'm at a fork in the road here and could really use some sharp minds advice I'm new to engine management I'm learning but new
                so microsquirt was my original plan but I'd need a map sensor and the coil on plugs
                Looking at $620 ish
                Was just talking to the guy on BP performance about his Evo 8 kit I don't need the HP capabilities of that setup but my thinking is better the software better the tune possibility Evans tuning is just down the road from me and hes supposed to be an amazing tuner there's always hardcore evos and s2000s there
                This kit comes with literally everything for $850
                Festiver
                93 L find/5 speed
                BP/g15mr swapped
                89 festie
                rustful
                93 festie
                advanced suspension
                kai/skeeter camber
                b3t/g15mr
                • http://www.stratifiedauto.com/index....roducts_id=227
                  I prefer megasquirt. There's a lot more support for it.
                  Better Than Nothing Racing
                  Way too many cars
                  :woc:
                  • Originally posted by shorestiva View Post
                    Hmm I definitely like that kit be about $800 because id still want to go coils
                    Festiver
                    93 L find/5 speed
                    BP/g15mr swapped
                    89 festie
                    rustful
                    93 festie
                    advanced suspension
                    kai/skeeter camber
                    b3t/g15mr
                    • one step forward 5 steps back so I was trying to run the wiring for my wideband and I hit a harness with the drill so everything has to come out to me to fix it ripped up 4 wires but now I can fix up some previous wiring and some P/o rat nest
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • What wires did you hit? Taking off the dash and stuff sucks big wang!
                        Dark blue '91 B6t + E series
                        Something new breaks every day
                        • Good opportunity to clean your heater ducts, and heater fan too. My fan was covered in dust and crap and it works much better and quieter now.
                          • Originally posted by Eviljimchicken View Post
                            Ayeee it's you and the dash harness yeah it sucked but now I get to fix up alot of wiring sleep easier at night
                            Festiver
                            93 L find/5 speed
                            BP/g15mr swapped
                            89 festie
                            rustful
                            93 festie
                            advanced suspension
                            kai/skeeter camber
                            b3t/g15mr
                              My duct tape dash actually blocked off all of the side vents so I deleted them just gonna run defrosters and center vents but thanks for the tip how do you clean the blower? Also do you know where to get replacement defroster vents and the foam seals
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • Originally posted by Festiver View Post
                                If you cant find replacement defroster vents with new seals I would assume you could just add some of the Foam Window Insulation with for a makeshift seal, I would probably add a little extra adhesive to the backing though.
