Festiver build thread
Festiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Festiver did very well doing a cold start ran all 4 cyls instantly and idled at 600 rpm so smooth noticed a slight hesitation when bumping the throttle but my thinking is it's still cold didn't run her for very long just wanted to test how she ran
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Ok so went to get the car up to temp make sure the cooling system is finished and the thermostat didn't seem to want to open weird since it was working fine in the other engine and the original thermostat didn't want to open either but it bench tested fine idk whats going on here
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Possibly not enough coolan? The T stat won't open in air, so if you've got a bubble stuck in there it won't open. Did you use a dual element t stat?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by Advancedynamix View PostPossibly not enough coolan? The T stat won't open in air, so if you've got a bubble stuck in there it won't open. Did you use a dual element t stat?
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Originally posted by Festiver View PostOh maybe and yeah I'm trying to use the factory dual but I ran it with no thermostat and my pump is good so how do a put the thermostat in without getting an air bubble? Or just try again and hope it works
Sent from my XT1585 using TapatalkLast edited by Advancedynamix; 12-28-2016, 04:06 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Originally posted by Advancedynamix View PostI squeeze the upper radiator hose to burp it. Squeeze it a bunch of times. Then, when you start the engine, leave the cap off and keep topping off the radiator while the engine warms up. Finally, when it stops burping out air and won't take any more water I rev the engine till about 3k rpm, the coolant level should drop a bit in the radiator. While the engine is at 3k rpm, I fill the radiator to the top of the filler and put the cap on and then I let it go back to idle. If you let off the throttle with the cap off the radiator it'll spill out when the engine goes back to idle. So make sure you get the cap back on before you let off the throttle. This is my method, and seems to always work.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
did some wire clean up came out better than I was expecting now I'm not embarrassed of my engine bay wiring lol
also fitted the new extremely large air cleaner I'm thinking that's a relatively cool area when driving I want to redo the piping in PVC or maybe charge piping kit?
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
got the typical teen can on also made a complete new exhaust system much nicer to look at lol sounds great
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Just had my buddy bump the throttle with me behind it. Sounds much better than I thought very deep and aggressive with very little whiny farting I'm happy with it
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Ignore this link is brokenLast edited by Festiver; 01-02-2017, 10:17 PM.Festiver
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Ignore this tooLast edited by Festiver; 01-02-2017, 10:18 PM.Festiver
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
