So at this minute OverKILL is down! Carlos and i went to adjust the tune and something went wrong. AEM was not readying the correctly. So last night i bought new plugs but couldnt find any feeler gauges to set my gaps. Got a new feeler gauge set and i hope to have the car back up and going tonight. We might have to start back at the binning however. All new tunning so its going to be a few days i bet. I hope i can get it straight before i mess anything up tho.
OverKILL!
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Originally posted by azgtx View PostAgreed, I have see these gears sheared off. But if you are going to eat a gear that is one that might not hurt the interior of the tranny. I had GTX awd tranny that blew the fifth set and no damage to the primary or secondary shafts. Crazy.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Well i sure am! PM sentLast edited by mikemounlio; 03-09-2017, 08:53 AM.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Turns out the AEM Wide-band that cam on OverKill is bad! It does not read the true afr. It just kinda shows whatever it wants to. I would say the car was ran on race gas and overheated the sensor. Ill put my other wide-band on tonight and get ready to finalize the tune this weekend. The car is running again tho. I will upload my latest video in a bit. In the video you can hear the car make a different sound. To me its like lifter tapping or valve float or something. IDK what it is. It happens when in boost hard. If i were to stay at 15 psi it would never happen but thats not gonna happen...
This noise was here on the last turbo and tune and still here now on the new turbo and basic tune i have for now. I really want to know what the sound is and how to correct it. At this time i dont know if its a lean condition or not as my WB is not working.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Pre-ignition? Sounds a bit like marbles?Trees aren't kind to me...
Race gas burns cooler than pump gas, not hotter. If it was leaded race gas it might have contaminated the sensor. The description of your noise sounds like detonation (pre ignition, like what Arty suggested.) If you hear that noise, let off IMMEDIATELY. Detonation will turn your engine into a pile of scrap metal in a matter of seconds at the power levels you're talking about.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I see. thanks guys. looks like i have more work to do.
Any idea on how i can try to get rid of the upper rpm detonation? I would like to keep my boost levels at least at 20 if i can get it to work.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I guess once my afr is under control i shouldnt get so much detonation! I hope to have it solved this weekend.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Take a bore scope and inspect the tops of your pistons. If it's starting to look like the surface of the moon, that's pre-ignition (detonation).
There is no positive outcome with it present (shattered pistons/rings, burnt/cracked valves, that aforementioned pitting, bent rods)Trees aren't kind to me...
What is the compression ratio on that engine?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I have no clue the compression ratio!1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
