Alice and The Festicle
A mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82
Shifter Brace Trans Bushing
Kia Part# 0B092 46041A mechanic knows how; A technician knows why.
Just ordered 50^2ft of Kilmat from Amazon. Just under $60A mechanic knows how; A technician knows why.
Making some progress with the deadener. Pretty much done with the left door, hatch, roof, and rear wheel wells. The right quarter panel was fairly easy. The left side is harder because of evap and the filler neck. The rubber is a bit stiff and I don't feel like dropping the tank just for a tiny bit more room, so I'm just gonna slip the evap out of the way and work around the filler neck.
How long does it take TFS to ship things to California? I ordered some tail light gaskets last weekA mechanic knows how; A technician knows why.
Originally posted by ryanprins13 View PostOn my car the filler neck and all those hoses were pretty easy to remove. Made it much easier to do the sound deadner.
Sent from my SM-G920W8 using TapatalkA mechanic knows how; A technician knows why.
Bought 2 12sqft boxes of 1/2" DynaLiner from amazon, ~$73/each. That was a bit more than enough for both doors and the roof. I think I'll need 5-7 more boxes. Waiting to put deadener and insulation on the floor until I'm done with all other areas so I don't tear it up while crawling around.A mechanic knows how; A technician knows why.
Today I pulled my dashboard out of the garage to see if there are any tight clearances where I shouldn't put insulation or deadener, then I thought I should ask,
While I have my dash out, is there any maintenance I should do on it? Oil the HVAC cables? Condition any plastic ducting? Do anything to the cluster?A mechanic knows how; A technician knows why.
Originally posted by Sid_RallyX_82 View PostToday I pulled my dashboard out of the garage to see if there are any tight clearances where I shouldn't put insulation or deadener, then I thought I should ask,
What did you do for drainage on the floor? It looks like the deadener is covering the holesA mechanic knows how; A technician knows why.
