What cars/years/models were the installed B8sohc 16 v in?
Why isn't the B8 swap more popular?
Only 1 car. 1990 - 1994 Mazda Proteges. Luckily for us, Mazda made millions of these.Festiva: Because even my dog can build a Honda.
Next quest is to find an affordable manifold for that b8-me.
eurotiva:Are you using a flange on the end of the oem manifold or was something made from scratch?
I was tempted to purchase a "chingchong" ebay manifold for the BP engine, then have a B8-me flange made from a gasket, finally rewelding it to the BP manifold. Is that a bad idea? Is the OEM sufficient flow for the turbo and limitations of the stock assembly?1993 GL 5 speed
You can keep the a/c but you have to use the water pipe that comes with the b3 bc it clears the a/c compressor. I am using a stock b8 manifold. My turbo is mounted at the rear of the car for multiple reasons. 1. I had to have a/c bc I live FLorida. 2. I wanted stock temps. under the hood. The stock b8 manifold is alot larger than a b3 manifold. And the sohc 16 valve motor only came in protege dx.Last edited by eurotiva; 08-04-2009, 01:19 AM.-Greg
Redneck Engineer
FOTY - '09
is it a direct bolt in? if i got one, what would I need? I have an atx, so my tranny can probably handle the B8 16v hp, but whatabout other parts? I know I need ecu. do I need the b8 16v fuelpump, airfilter and other such things?1997 Ford Aspire, MTX, Teal, B3E - "Trusty"
1997 Ford Aspire, MTX, Red, B3E - "Eggy" (RIP)
1989 Ford Festiva LX, ATX, Maroon, B3E - "TBK" (RIP)
1991 Ford Festiva GL, ATX, Red, B3E - "Festiva GT" (RIP)
You will need the ecu and the maf (mass air sensor) and that's it. All else bolts right up. I did not even cut any wires in my harness. It also helps to get the exhaust flange that meets the cat. on the donor car. The front motor mount hole did have to be moved about 1 inch tho.-Greg
Redneck Engineer
FOTY - '09
Can you use the whole down pipe from the exhaust manifold to the cat?Festiva: Because even my dog can build a Honda.
Originally posted by FestivaFan View PostOnly 1 car. 1990 - 1994 Mazda Proteges. Luckily for us, Mazda made millions of these.
-Aspire brake swap COMPLETE!
Originally posted by ejp2fast View PostAny specific trim level?Festiva: Because even my dog can build a Honda.
i dont know why i didnt think of doing this swap for my winter car... it seams like suck a easy swap and my local JY has TONS of them...
Mike, AKA the sasquatch
It is easy and you use the down pipe from the protege because it has flex to it. Alot of jy have these and plenty of them.-Greg
Redneck Engineer
FOTY - '09
so you dont even need to make your own down pipe? it just bolts up?
