I put it in around 630 today and getting oil change at around 830 in the morning.
Sea-foam best thing i ever put in my festiva
Yeah I was going to say to make sure you read all the directions and internet info. Many people have there preferred ways of using seafoam and how to use it. Soooo just make sure you follow the directions and read about it before diving in :pOriginally posted by ENEMY_ View PostWell that sucks, I poured it in mine I guess I will go get an oil change first thing in the morning
Stuff works great though! and your festy will be fine I'm sure-------------------------------------------------------------------------------------------
My Musica! Click me!
It says right on the can that it is alright to put in the oil.Originally posted by Evil D View PostI would either slowly pour it down the carb if you're carbed, suck it through a vacuum hose, and/or pour a can in a full tank of gas. All of them are a good idea. I've never put it in the oil though...that doesn't sound like a good idea.
If any of you have Subarus, this stuff works absolute miracles on them! Something about the boxer design builds up a lot of gunk in the heads. Half a can into the intake via a vacuum hose, let it sit for 10 minutes, start it and put the engine under load for a bit, car will run much better. I've done it to all 7 of my Subies and my Festy. Greatly improved the idle in my little Ford.
ed'90 Festiva L Plus-toy
'94 Impreza 2.0T-fast
'97 Hardbody-lowered dd
'05 CRF50-pain bringer
GenevaDirt: When I started typing the comment I made, there was no comments under the one I was responding to. Unfortunately I was on my cell phone at work trying to help a forum member and my browser didn't update to show your comments. If my comment caused you that much stress, I'll pm the owner and ask to disable my account. I can only speak from my experience with Seafoam. Several people locally told me it would work on the HLA's/lifters I had that were clicking. I left it in (1/2 can) and drove the car for about 3000 miles before the next oil change.Originally posted by GenevaDirt View Postlike I said...it depends on the condition of the engine when you pour it in. If you have no clue....I would not suggest pouring it in the crankcase.
As stated above, it PLAINLY states on the can that it is for use in both gas and oil. At least the southern version does. Didn't realize I had pee'd in your cheerio's until I read your comment. Oh,my motor has approx 100K miles on it and doesn't use oil.Last edited by Team Lightning; 09-06-2010, 05:51 AM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Get's my vote for "Best anology" of 2010! roflOriginally posted by Aaronbrook37 View PostThink of it like combustion chamber toothpaste...
I'm using it right now to remove that buildup of tartar, I mean carbon, from the tops of the pistons on an engine I've just disassembled.Last edited by iceracerdude; 09-06-2010, 06:43 AM.
FYI, Easy Off oven cleaner works well for cleaning pistons too.Originally posted by iceracerdude View PostGet's my vote for "Best anology" of 2010! rofl
Thank you sir!Originally posted by iceracerdude View PostGet's my vote for "Best analogy" of 2010! rofl
I think it's the best way to describe it, even better than steam cleaner imho. TBH, you don't really need to - your meth injection system will serve the exact same function. But if you need extra coverage for off-boost driving, then go for it.
Yep - basically anything of a friendly-to-engine nature will work. Water, methanol, alcohol, ethanol, Seafoam, lighter fluid, etc. You just have to be careful if it's water, but it'll work really well for this purpose if done in really really small doses.Originally posted by Evil D View PostFYI, Easy Off oven cleaner works well for cleaning pistons too.1988 Chevy Sprint Turbo 997cc
I kinda gave up on seafoam the effects never seemed to last. On this last Festiva I put 1 ounce of MMO in each cylinder and left it a week. Next trip I take I'll put two ounces in each and leave it. I kick myself for not doing a compression check but it did seem to lessen blowby purrs on the highway now. Also put a couple ounces in the oil which I shouldn't of done with a few oil leaks. With MMO you can leave it in the entire oil change unlike seafoam.91 rusty Festiva 260k
Thats exactly it, seafoam is a combustable agent thats why everyone notices the big diffrence when running it in a fuel system. Once its gone so is the performance. I have noticed this along time ago. Ya it is good stuff for cleaning deposits and such but half a 5th of moonshine does the same thing except shoot fire out the exhaust.1991 stiva.
Sometimes, if you have too much carbon build up, loosening it up is not the best idea. It's like doing an engine or transmission flush. When it comes to cleaners and additives, you have to determine how bad it really is and weigh the possible consequences.
I will say, I've only had good results from using Seafom. However, using the Pennzoil Ultimate in my Festy was an epic fail! I now loose about a 1/2 quart of oil every 100 miles through the breather due to excessive blow-by. The motor is sparkling clean inside, but no ring seal left. The oil did not cause the issue, it just exposed the mechanical condition.Brian
Don't ya think you went a little over-board with your comments when Geneva was only stating a calm statement to ad to the discussion of sea-foam?Originally posted by bebandit View PostGenevaDirt: When I started typing the comment I made, there was no comments under the one I was responding to. Unfortunately I was on my cell phone at work trying to help a forum member and my browser didn't update to show your comments. If my comment caused you that much stress, I'll pm the owner and ask to disable my account. I can only speak from my experience with Seafoam. Several people locally told me it would work on the HLA's/lifters I had that were clicking. I left it in (1/2 can) and drove the car for about 3000 miles before the next oil change.
sea foam story
wife drives a 04 hyundai that has 150k on it. last month i though a can of sea foam in it (1/3 in the intake) before i started to fill the tank @ the gas station put the rest in the tank. she was really nerves about all the smoke. i drove to portland O.R. (200miles) and then re-filled the tank and let her drive back she was extremely impressed with the improvement it made. the fact that she noticed the difference when she doesn't notice the engine light come on or.... anything, then when the improvement was enough for her to notice, was impressive to me73 pinto sedan 2.0/auto stock
74 pinto h/b turbo 2.3/t5/8.8=4:10
79 pinto wagon 2.3/4speed light mods
96 f250 daily driver work/tow rig
93 festiva 1.3/5speed
1973 pinto custom teardrop trailer
http://www.youtube.com/watch?v=fzDxRzM4vMM
wanted cars
79 ford courier
60-70 datsun PU
LEE CAR
horizon 2.5 turbo swap
75 honda cvcc b18 or vteck swap
71 datsun 510 wagon (4th car ownd 1 i drove daily)
older vw rabbit & dasher
1936 ford truck
cobra kit turbo2.3 5speed
I was thinking the same thing. As a fellow mechanic Ive seen plenty of good and bad byproducts of many engine "cleaning" additives. Some work well and some don't, usually depends on the engine to begin with and whats crudded and where (which is exactly what Geneva said).Originally posted by Damkid View PostDon't ya think you went a little over-board with your comments when Geneva was only stating a calm statement to ad to the discussion of sea-foam?
Telling someone off because they are the wary consumer in a thread full of advocates is a little over the top, particularly when the item in question is related to the longevity of your vehicle.1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
So heres the story My Festiva ran like complete crap before I got the Sea-Foam, I added it to my gas tank and ran it hard for 150 miles and now the car seems to run perfect with no weird smells, no more idle problems, and it doesnt stall at every light or stop sign anymoreI have one tough looking festiva...even though it has 63hp :dj:
