Originally posted by Pu241
Fuelly
Originally posted by Pu241 View PostOK, joined fuelly and entered first fill up data, but can't get the badge to show up in my sig. any suggestions?
It keeps telling me "invalid file".
OK, a little playing with the address and I get "Invalid URL", progress?
OK, so how did you set up your sig.
PM if you want.
Happy to experiment, but I've already loaded 3 fill-ups and notes into this one and messed around with getting this to link to my FF.com account for the better part of today.
If it doesn't work, I'll just go my merry way and work this through fuelly.com'93 Blue 5spd 230K(down for clutch and overall maintanence)
Yeah, but not the way it was originally described but it is working!
So Darlo what fuel are you running; 87 real gas, or 87 10% ETOH, or 89 octane.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by Pu241 View PostYeah, but not the way it was originally described but it is working!
I just put in the cheapest one, lol
Going to run a few more tanks of 87 10% ETOH(crapoline) before I go to 89.
3 tanks in the next two weeks for good baseline.
Well sort of because of lower ambiant temps will likely see a decline anyway!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Previous festiva experiece should net me 2-3 mpg gain, but not in winter!
Used to be all I ran, because of MPG increase.
BP festiva showed no such increase in MPG though.'93 Blue 5spd 230K(down for clutch and overall maintanence)
John your 155/80-12's are 3.0% taller than stock 145/80's. Thats whats causing your speedo to be off a little. When I fill up the 92 I multiply the miles by 1.03 to correct it.
Back when my 93 was stock and I was rolling on 175/70-13's I multiplied by 1.073 or something. Those were way taller than stock.91GL BP/F3A with boost
Originally posted by bhazard View PostJohn your 155/80-12's are 3.0% taller than stock 145/80's. Thats whats causing your speedo to be off a little. When I fill up the 92 I multiply the miles by 1.03 to correct it.
The tires couple with the inherent Odo error leaves me with 2.5% more mileage than I really cover.
And for my own calculations, I use a correction factor and all is fine.
However, when using something like fuelly, the first thing I saw was a Odo reading. Without the option of using a "trip Odo" someone might think I was "cheating" if they never saw consecutive Odo reading due to the correction factor. Using the "trip Odo" solves that issue. Besides I know my GPS is more accurate than either my Odo, or mile markers. I just have to remember to let it power up before I move.'93 Blue 5spd 230K(down for clutch and overall maintanence)
