Would like to give 100% gasoline(not worrying about non-energetic additives) its own thread & to that end I've given the title, pure-gas.org, a website where gas station listings throughout the U.S., have 100% gasoline. There are other websites showing where 100% gas can be obtained, but with my limited experience, pure-gas.org seems to have very up-to-date & comprehensive listings. 100% gasoline doesn't have anything to do with octane ratings, but generally deals with non-ethanol gas. If other posters can delineate other ingredients to be avoided, please post.
My experience with 100% gasoline in the past has been very uninspiring. In my case, I may have used gas, said to be 100%, that wasn't 100% gas. Also, I only used one, at most two tanks of 100% gas to make quick & I believe, inaccurate determinations of the abilities of 100% pure gas.
Hope to explore 100% gasoline here, not only for its mpg capabilities, but also for possible extra power, drivability, increased range (associated with greater mpg), engine wear & longevity capabilities, etc. Hopefully many Festiva posters know more about 100% gasoline than I do or this thread will be short.
So far this thread is boring. Let me tell you the exciting part. One of my tanks in my '88 carbureted Festiva, soared to 57+mpg! When I mentioned this outstanding result, some posters were stunned, believing I talked in generalities, one even saying I didn't compensate for undersized tires. I, myself, wondered if the fuel hose may have clicked off prematurely, & my tank wasn't really filled. However, the following tank, altho not near the travel tank giving 57+mpg, was still 47mpg, which I consider v. high for the travel conditions I was under at the time & the winter-blend 10% ethanol that has been my experience for this time of the year. As for undersized tires, I compensate for this by determining the off-set, both by highway mileage markers & by my GPS.
Tho my fuel-injected Dodge Caliber & my wife's fuel-injected Hyundai Accent aren't showing the outrageous results of the Festiva, my Caliber just turned in its best ever tank, 37.3 mpg. Again, that is comparing a late November tank of 100% gas that had several cool-downs on the car over 3 days, to my best ever 35.6mpg of 10% ethanol, higher mpg summer-blend(as opposed to 10% ethanol,lower mpg winter-blend) from a nice hot summer day of continuous driving & NO cool-downs.
Both Festiva & Caliber have set highest mpg marks within 3 weeks of using 100% gasoline, during this latter part of the year, where 10% ethanol, winter-blend gasoline gives lower than yearly norms for mpg.
Beyond mpg, my Caliber with its CVT ultra smooth transmission, seems to give very slightly better smoothness & responsiveness, especially at lower speeds, when being very carefully feather-footed.
I was hoping for extra smoothness from 100% gasoline for my Festiva, which IS carbureted & NOT smooth, especially at times of shifting. But Festiva continues have its smoothness problems, & is as it has been for 21 years when nearly new. Sometimes a can of HEET helps to lock up water in the gas tank, which I think is a problem here in the sopping wet Pacific Northwest. HEET seems to help smooth Festiva operations at times.
