Originally posted by TominMO
MPGs run, Aspire SE
According to Matt I should see a couple or three MPGs of improvement just with the injector balancing. I will test that first, since they will come back to me soonest; then the header addition, then the stick-with-bumps.
Mikey, I thought you were ordering the MPG cam too?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostAccording to Matt I should see a couple or three MPGs of improvement just with the injector balancing. I will test that first, since they will come back to me soonest; then the header addition, then the stick-with-bumps.
Mikey, I thought you were ordering the MPG cam too?Last edited by mikeyjd; 06-26-2013, 09:43 PM.
Originally posted by mikeyjd View PostI am. It sounds like you're gonna have yours first though Maybe I'll wait to see your numbers on the other upgrades and to see if I should do the whole shabang as well. How much is all of it running you?
Header = $340
MPG cam = $180
Injector balancing = $81 IIRC
plus shipping
Injectors will come back first, so that will be the first test. Then header, and finally the cam.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostWell, since all prices have been quoted by him on the forum before, I will discuss them.
Header = $340
MPG cam = $180
plus shipping
Injectors will come back first, so that will be the first test. Then header, and finally the cam.Last edited by mikeyjd; 06-27-2013, 07:41 AM.
Originally posted by mikeyjd View PostThe header is the one I'm most interested in seeing the numbers on as it's the largest investment (my festy was only $250 lol). 2-3mpg for the injector balancing would be worth $100 to me. The reason I'm waiting to do mine, is I'm planning on taking it to his shop and having him do it all at once. I want to make sure I'm doing everything I want done since it's about 10 hours round trip. Did you decide not to get the adjustable FPR unit?
Got the injectors back, and am waiting for an intake mani gasket kit (due Monday) so I can pull the top half of the mani, to get the old injectors out and make the swap. (These injectors came out of a JY head I picked up a couple of months ago. So did the cam I sent Matt, since he didn't have an Aspire cam to work with.)
Went back and forth about the FPR, but for this application decided not to. The cam will make sure the fuel is burned more efficiently. While reducing the pressure from (just making up numbers here) 40 to 32 or 36 might make some MPG improvement, and it sure would look cool in the engine bay, it seems to me to be the least useful addition; or rather, the lowest priority in terms of bang-for-buck. All cars should have the injector balancing done IMO, and the MPG cam will probably give the best overall improvement. Reducing fuel pressure by say 10% will probably help too--maybe 3-6 MPG?. You could even argue that the FPR could be used as a poor man's MPG cam by simply letting less fuel in, and not get the cam at all, but the cam should be the better investment long-term. Possibly someday I will buy it too, just to see if it matters, and even better bragging rights if I can hit 65 or 70 MPG by buying it. If not, I can use it on a motor built for power rather than MPG.Last edited by TominMO; 07-09-2013, 08:26 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Tom, have you considered an intake spacer (extention between upper and lower halves of the intake, for the purpose of lengthening of the runner and therefore lowering the peak torque RPM)Trees aren't kind to me...
Originally posted by FestYboy View PostTom, have you considered an intake spacer (extention between upper and lower halves of the intake, for the purpose of lengthening of the runner and therefore lowering the peak torque RPM)90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
a 1.5-2" spacer would be in your realm of fab and installation expertice. Nate was working on such an item a bit ago, but no one has tested it yet that i'm aware of. note that Matt has basicly done the same thing by fabing an upper intake (longer runners) and the torque curve was near table flat out past 4kTrees aren't kind to me...
Originally posted by FestYboy View Posta 1.5-2" spacer would be in your realm of fab and installation expertice. Nate was working on such an item a bit ago, but no one has tested it yet that i'm aware of. note that Matt has basicly done the same thing by fabing an upper intake (longer runners) and the torque curve was near table flat out past 4k
TominMO, if interested it's yours, for the data generated with it.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by Pu241 View PostStrange you should mention that, I happen to have the spacer Skeeter made for me, here in St Louis.
BTW mikey and Arty, slight delay on injector install as I am having Matt build and send me an FPR after all. Will install together, but test lower pressure separately. Should still be next week tho.Last edited by TominMO; 07-10-2013, 09:38 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
You are welcome, my disciple of MPG!
Will have to source longer intake bolts and another gasket or make a gasket via permatex which fits between intake and spacer.
Might be able to just use two intake gaskets, for an off the shelf solution.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Tom, i currently have my FPR set at 42psi whilst deadheaded... since the install, i've noted an average of 2mpg increase over the factory equiptment (all other things being the same mechanicaly since the rebuild, and honestly, my driving habbits have gotten worse since the install). i suspect you should see better than that with your injectors. being that i dont have a wide band installed yet, i'm going to leave things as is untill the header is installed later down the road. Matt suggested that i start at ~40# on the FPR and it came to me set at 42 so i left it there.Trees aren't kind to me...
Originally posted by FestYboy View PostTom, i currently have my FPR set at 42psi whilst deadheaded... since the install, i've noted an average of 2mpg increase over the factory equiptment (all other things being the same mechanicaly since the rebuild, and honestly, my driving habbits have gotten worse since the install). i suspect you should see better than that with your injectors. being that i dont have a wide band installed yet, i'm going to leave things as is untill the header is installed later down the road. Matt suggested that i start at ~40# on the FPR and it came to me set at 42 so i left it there.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
i see long meaningfull conversations with your spark plugs in the future. i'd stock up on several sets for said experimentation, as color and arc location are good indicators of combustion events/timing.Trees aren't kind to me...
