uh oh stuffs getting interesting now! I hope you do things individually with a couple tanks between changes so I can see whats worth buying and what's not! haha...do the fpr last!
MPGs run, Aspire SE
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
running the FPR is going to smooth things out and should NOT be installed last (last should be the header). i would START with the FPR, that way it's there to support the cam and header as they are installed.Trees aren't kind to me...
I agree.Originally posted by FestYboy View Postrunning the FPR is going to smooth things out and should NOT be installed last (last should be the header). i would START with the FPR, that way it's there to support the cam and header as they are installed.
To get the full benefit of either.
Or all together it would me most beneficial to install it first.
Not to mention if he wanted to do a stock run.
he could just dial the fpr back to stock pressure.
Will probably redo the exhaust a bit; slightly larger pipe and muffler, no more than 2". O2 sensor was done pretty recently. Nippondenso of course.Originally posted by rmoltis View PostYou gonna keep your stock exhaust with the header?
And are you gonna get new o2 sensors while your at it?
Sounds like fun.Last edited by TominMO; 08-21-2013, 06:56 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Can't believe I said fuel pressure gauge. Meant regulator.Originally posted by FestYboy View Postrunning the FPR is going to smooth things out and should NOT be installed last (last should be the header). i would START with the FPR, that way it's there to support the cam and header as they are installed.
My concern is how to adjust it? rmoltis IIRC mentioned that I might actually overtax the injectors by dialing the pressure back on the FPR. My thought had been that by putting less pressure through, say 35 lbs, it would help MPGs, kinda like putting in a smaller primary main jet in a carb. But I don't know enough about fool injection to know whether this is correct thinking or not. I was planning on just leaving it at stock pressure, i.e. not a factor at all.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I think I get what your sayin.Originally posted by TominMO View PostCan't believe I said fuel pressure gauge. Meant regulator.
If you reduce the pressure the fuel may not atomize fully through the injectors?
I think turning up the pressure would work good.
But turning it down may turn the spray into a stream
If turned down to low.
Only you will know for sure.
I bet matt would have some good advice on this matter.
Good luck on your endeavors.
Can't wait to see the results.
I will PM Matt on this question. Arty can chime in too BTW. I think what you or someone else was saying is that lower pressure might make the computer overtax the injectors by keeping them open longer, to get the same volume of fuel per cycle, something like that. But IDK if our cars' computers are even that smart. Nor am I sure that raising the pressure will do any good, or do any harm (or not). I figure there is a reason that the stock little FPR is set the way it is (whatever value that is).Originally posted by rmoltis View PostI think I get what your sayin.
Can't wait to see the results.Last edited by TominMO; 08-21-2013, 07:46 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
as mine sits, i'm at 42psi and have left it as such. 44mpg running arround Mass., and 34+ beating the snot out of it while short tripping. THAT is a 2mpg improvement over stock pressure AFTER the head rebuild. so yeah, more pressure GAINED mpg.
up to 5000 RPM, the injectors fire TWICE per combustion event per cylinder, so at low rpms, the injectors are open a VERY short time per pulse. I figure that the higher than normal rail pressure allows the pattern to actually happen and also atomize properly.
after (pay attention Zanzer!!!) 5000 rpm, the injectors fire ONCE per combustion event per cyl, because otherwise the injectors would start to go 100% and that makes for poor power.Trees aren't kind to me...
I too have my pressure set at 42psi.
And it seems to do well.
But with the mpg cam designed to make the car gulp in less air.
Wouldn't tom need less fuel so it won't run rich.
Or will his header offset that.
And need a stock pressure or barely higher?
well i'll ask this: what's the point of an adjustable FPR if you're going to run stock pressure?
in any case, reguardless of the cam profile, the idea is to get the MOST cylinder pressure for your power band (the MPG cam is designed to make the most UNDER 4000 rpm). given that, having higher pressure allows the injector to be closed longer (less lag) for a given volume of air. you have to remember that the ECU can adjust the injector pulse length to maintain it's programed ideal AFR.Trees aren't kind to me...
I guess I'm just uncertain how much the computer will adjust things.
Can't wait to see the results of the mpg cam either way.
1. I was coming to that conclusion myself, but would like to play with fuel pressure just to see what happens.Originally posted by FestYboy View Post1. what's the point of an adjustable FPR if you're going to run stock pressure?
2. you have to remember that the ECU can adjust the injector pulse length to maintain it's programed ideal AFR.
2. Aha, that's what I wanted to know. If our Festy/Aspire computers are smart enough to compensate. So with lower fuel pressure, the computer will make the duty cycle longer? Will that be a problem? And with higher pressure, the duty cycle would be shorter? And BTW what is the stock pressure?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
stock is ~36... yes duty cycle times will change to compensate for pressure. shorter bursts at higher pressures typicaly yield a finer spray
experiment time!!!: take a straw and a full glass of water. insert the straw into the water and seal the top off. remove the straw and lightly place a finger at the bottom of the straw (pintle valve). now uncap the top of the straw.... the water slowly dribbles out, large droplets fall straight down, a puddly mess.
now do the same steps again, but instead of lightly pressing on the bottom, press a little harder and then BLOW into the top of the straw (pressure). now you have a spray/mist of water that goes all over the place!
the volume of water hasn't changed, but the way it's delivered and dispersed does. same thing with the injector!Trees aren't kind to me...
If you were referring to the other post then we were only looking for pulses to verify the ECU and spout signal was not dead and my method worked just fine, don't knock it till ya try it :pOriginally posted by FestYboy View Postafter (pay attention Zanzer!!!) 5000 rpm, the injectors fire ONCE per combustion event per cyl, because otherwise the injectors would start to go 100% and that makes for poor power.
100% duty cycle also makes for a short injector life.
Tom, you typically want to keep the duty cycle at 80% or below. Running a higher pressure will help you on 2 fronts because the duty cycle will be shorter and the spray more atomized. The ECU will take feedback from the O2 and adjust as needed for mixture. As long as it has good inputs an ECU can compensate for a good bit more than people generally give them credit for....well unless it's a speed density system and you install a huge cam
The stock pressure on my aspire is 30-38psi in the factory service manual.
30 at idle and (high vacuum)
38 at wot (low vacuum)
Assuming this is for your aspire.
My other question is.
Since the ecu manages the injector pulse time and whatnot.
What happens at WOT when the o2 sensor goes into open loop?
Could this make things run overly rich if turned up too high?
Since it has no feedback on air/fuel values?
