The E series use a 7 1/8" clutch, swapping to the F series gets you a 7 1/2" clutch or you can swap in a B6D flywheel and bump it up to a 7 7/8" clutch. That should hold more than your B6 can throw at it
i thought the point was to hold power and not have to fab mounts.
Well my brother if it comes to modding 1 mount vs changing a whole flywheel or spending 180 on a decent clutch and im only paying 200 for a superior trans and it comes with a motor attached to it.... What would you guys do. Input?
-90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
-90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
An Exedy clutch might work for you. When I put my B8 in the car, the used one I had (about 50,000 miles) held it for about two months before it began to slip.
The Bahnhof slipped from day one, even after babying it for the first 500 miles (like they recommend)
I'm running a Sachs clutch right now. Can't make it slip no matter how hard I try.
I would like to know more about the Sachs clutch, were do I find it, money, etc.
Notice how this thread has gone from cheap E series clutch to an F series install.
Why stop there? Get a G
why the f-bomb did I miss this!? still think im going for the b6 and f box cause its a double win for me. I get a clutch/better trans out of the deal. win - win then I can sell flamer to my friend win - win - win then he can become a member win - win - win - win... pickin up what im puttin down.
wouldn't mind having a g at all. can the 01 rio g bolt up to a b3?
the Rio transmission should bolt up to any B series engine (probably the Z series too). You would need the flywheel (and matching clutch), the starter and the block plate.
^ this is def good stuff to know for the future. wish dickmeyer would have had your g box mod when he was running is monster b3 build because the trans and axles just couldn't handle it
