as stated above, i also checked to see and verify that there are pre-tapped holes 7" on center above both rear windows and above the passenger window except that the ones above the pass. window were already used by the bolts that hold the motorized belt track. this shouldn't be a problem on manual belt cars with the bow stiffened headliner.
Avella (Aspire) brake booster upgrade for correct feel with Aspire brake transplant. this is the 8" can for MT w/o ABS. KK370 43 800A. when only new will do. $125.24.
this is more for our Philipine buds since i don't think our 2 door hatch is tapped for these Rear Seat Center Belts. KK343 57 740B04. $17.14. at that price though i'll screw em in anyway. these don't match our US belt in color though. they're a little lighter.
this is more for our Philipine buds since i don't think our 2 door hatch is tapped for these Rear Seat Center Belts. KK343 57 740B04. $17.14. at that price though i'll screw em in anyway. these don't match our US belt in color though. they're a little lighter. ]
When I added the middle set of belts I just used the existing holes as they are far enough apart.
Ian
here's the lower pipe nest (PIPE 1 on the diagram) for PS. a little pricey but probably cheaper than having one made. KDT01 32 410. $55.52. unfortunately, PIPE 2 is no longer available.
unfortunately the armrests that these fit into are no longer available. some members in the Philippines or the UK might sell a pair. PW switches are interchangable between LHD/RHD cars. MAIN SW - KK12B 66 350 04. $22.86. PASS SW - KK12B 66 370 04. $14.86.
I'm after a set.. Capri xr2 should be about the same as these.
sent from the depths of hell.
Avg Economy:
Highway - 7.32L/100km
City - yet to be determined.
I already have those PN's saved but was wondering where one might find the wiring for such an install. LOL but seriously.
Go after the mercury Capri wiring.. It'll effectively be the same thing and tbh I don't think the festiva will mind too much as mine seems to be happy with the upcoming engine upgrade
Avg Economy:
I stripped all the wiring in case of something.. Even mirror wiring down to the inertia switch in the boot.. The whole shebang.. Even if you don't need, know in the security of having it in case.. After that, if you're wanting to save on wiring for other projects, cut up the existing loom and get some jars or reels and reuse them.
Avg Economy:
Here is the part number for the left hand long armrest that I purchased on eBay UK.
The length is compared to our stock armrest. I removed the connectors off of the original wiring harness and transferred them over to Mazda MPV door harnesses, because I also installed power locks + speaker ready. I still have the Pride door harnesses without the connectors to plug into the window controllers.
